First post, by 1ST1
There were a few 486 mainboards where an i860 could be installed, Olivetti LSX 5010/5020, CP-486 and M480, Hauppage 4860 mainboard for example. Is there any operation system which is able to use the i860 processor on such a system?
I have already checked, my result is until now, no. Wikipedia says that Microsoft originally designed to run Windows NT on the i860, but after testing it not only on emulator, but on real machine, they dropped i860 support as it was unexpected slow. I also checked the last year leaked source code of Win NT 3.5 and NT 4, there is no i860 tree. Also install ISOs for NT 3.1 habe no i860 directory (but 386, alpha, mips, ppc, ...) It also looks like if Linux never was ported to the i860 platform, what is surprising as "they" usually got Linux running on anything.
125.64 KiB
Njamnjamnjam...
Reply 1 of 8, by mr.cat
Wow, that board is something quite special!
Rather slim pickings on OSes it seems...apparently that NT port was really early work, so it wouldn't be usable even if it existed.
Information on this page: http://www.geekdot.com/category/hardware/inte … olivetti-cp486/
seems to suggest its purpose might have been to accelerate graphics (as i860 was ill-suited for general-purpose OS).
Also on that same site, this page may be of interest (see the part about "Xnix"):
http://www.geekdot.com/myriad-dash860/
According to this thread (from 2001!) an uClinux port exists:
http://lkml.iu.edu/hypermail/linux/kernel/0112.1/0264.html
But it seems there is no mention about i860, only i960:
https://web.archive.org/web/20010812190449/ht … ma/uClinux.html
Reply 2 of 8, by dionb
Here's some info:
https://www.osti.gov/servlets/purl/6167668
Oak Ridge did trials on clusters of these things with 386 'SRM' running Sys V Unix 3.2. The i860s run with a "simple OS kernel" NX, which accepts call from specially compiled C Fortran code running on the SRM.
Assuming a board like this uses the 486 as "SRM", it sounds like you should be able to do something with Sys V Unix 3.2 with specific compilers for i860.
Other paper:
https://esahubble.org/static/archives/stecfne … _stecf_0019.pdf
http://adsabs.harvard.edu/full/1993ASPC...52..570A
This is someone at ESO playing around with an add-in board with i860 in a SparcStation 2 to correct optics issues with Hubble space telescope. Different host, but same concept. Here an "MESL Hostmode Library" is installed, which again allows compiling Fortran and C code on the host system to run on the i860.
Intel blurb:
http://electro.fisica.unlp.edu.ar/arq/downloa … _Intel_i860.pdf
"A Unix V/386 or OS/2 hosts the application accelerator. which includes a runtime operating environment that maps I/O re- quests back to the host processor. A multiprocessing version of Unix System V Release 4.0 is under development for the i860 CPU. This is a joint effort by AT&T, Convergent Technologies, Intel, Olivetti, Prime Computer, and others "
39.63 KiB
Reply 3 of 8, by 1ST1
Interesting, but the i860 is not included as a coprocessor in this system, it can switch the main processor betwenn 486 and i860. The boards boots with the 486, but the i860 can be activated by software to take over the full controll, and can give it back. So it is possible to run a native i860 OS, if that would be available.
Reply 4 of 8, by winuser_pl
This chip was also interesting for me as I own a single i860, but I've never heard about any dedicated motherboard for this CPU. The architecture of this chip is also interesting. It could do "SIMD" back when 486 was not able to perform such operations and thus it could increase the speed of 3d rendering.
PC1: Highscreen => FIC PA-2005, 64 MB EDO RAM, Pentium MMX 200, S3 Virge + Voodoo 2 8 MB
PC2: AOpen => GA-586SG, 512 MB SDRAM, AMD K6-2 400 MHz, Geforce 2 MX 400
Reply 5 of 8, by mr.cat
winuser_pl wrote on 2021-01-05, 16:01:
Yes, actually on that geekdot site in the comments section there was an anecdote of someone who had demonstrated using that chip as a rudimentary 3D accelerator (thus gaining a job for himself).
Too bad it's just an anecdote...that could be interesting to see in action 😁
Reply 6 of 8, by lolo799
Reading the geekdot link posted by mr.cat, the CP486 page has a small manual and down the page for the LSX-5010 system there are images for a config and diagnostic floppies.
The CP486 manual has a list of compatible OSes.
The geekdot link in the 2nd post has manual and software for the Hauppauge card
http://www.geekdot.com/hauppauge-4860/, which are also available at http://edv-janssen.synology.me/ct_treiber_ser … prods/files.htm
This card has utilities to run programs on the i860 from the Dos or Unix host system.
Someone nicely shared a version of the Unix for the i860 with me, I can't publicly share it but I'll send a PM to 1ST1 to try some stuff.
Also the Walnut Creek Sys V r4 cdrom on archive.org has a few software sources for the i860 platform, like binutils, gcc and others.
