First post, by quackgyver
Has anyone had any luck using a HDMI-to-VGA signal converter in order to get a modern PC to output video signal to a '90s CRT?
The monitor I'm trying to use is an AOC 5ELR.
I've tried two solutions so far (one adapter and one signal converter) and neither of them worked.
One thing worth noting is that the CRT only has 14 pins.
Any ideas on what I could do or what product I could buy to make HDMI work on the CRT?
Game design studio: http://astrojone.com
Personal site: http://quackgyver.com
Reply 1 of 6, by Horun
Darry might know. Which adapters have you tried ? Which pin is missing ?
Pin 5 is not used so if missing is no big deal but if it Pin 15 that is for part of the DDC signaling which is probably required for the converter to know what resolutions the monitor can handle iirc.
https://en.wikipedia.org/wiki/VGA_connector
Have a Startech HD2VGAE2 that works OK from my newest video card to an old Dell LCD with just VGA input. Never tried it with a CRT....
added and after thought: does the video card (or device) have a DVI-I output ? Those can be directly converted to VGA without issue with simple passive converter.
If all you have is HDMI am curious what are you trying to feed the CRT from ?
My newest (2018 so not too old) Nvidia card has multi ports: DVI-I, DVI-D, HDMI and Display ports but bought the exact model on purpose because wanted those extra output features.....
Reply 2 of 6, by quackgyver
Horun wrote on 2021-01-09, 01:54:
These two:
395.63 KiB
25.21 KiB
The 9th pin.
The Startech HD2VGAE2 looks like the same white-labelled converter that I have.
It doesn't have DVI-I as far as I know. I intend to use the HDMI cable with a lot of different devices.
Different laptops. In this case I tried a 2012 MacBook Retina and a regular Windows 10 laptop.
Reply 3 of 6, by Horun
Ahh Your CRT monitor only supports to 1024x768 @ 60Hz, did you set the resolution to that or below before trying the monitor as an External on the laptops ?
Because the monitor is not HDCP compliant those cheaper solutions will not work if you try to feed a signal that requires HDCP handshaking including 720p mode (1280x720) AFAIK
Reply 4 of 6, by quackgyver
Horun wrote on 2021-01-09, 03:00:
I didn't change the solution. It's not really viable because I need to be able to plug any laptop in and use the external monitor without having to first change the native resolution of the laptop.
Is there any way to achieve the desired result with a signal converter?
Reply 5 of 6, by Horun
The Aten VC812 has built in selectable down conversion but costs about $150. It does support 1024x768 @60Hz output for your CRT.
https://www.aten.com/global/en/products/profe … nverters/vc812/
You can read the manuals and see if it matches what you are looking for....
Reply 6 of 6, by quackgyver
Horun wrote on 2021-01-09, 16:04:
Alright, great.
Thanks for the help. Much appreciated! 😀
