First post, by georgel
Hello. I am asking for your kind expertise about the behavior of this VGA card (Radeon RV620 HD3450). I am not going to influence your opinion in any way for now. Sure, if you have questions, please ask.
Hi,
whats the exact problem ? it crashes ?
sure its GPU problem ? not PSU ? i had a lot of crashes in my Shuttle until i switched PSU. The Card does not like any Ripple Current.
For HD3450 use Catalyst 6.11 Driver.
(need to look for exact version..)
What Chipset do you use ?
i use same Card on nforce 2 without Problems.
Not sure about the exact configuration. My Canadian buyer has opened a refund request in ebay ;( He claims two problems --system reboots from time to time and persistent incorrect reflections of the reflected graphic objects on screen...
