First post, by jdgabard
I do not have one on hand. So I cannot measure for myself. Does anyone have the dimensions of the MHZ displays, along with proper hole placements? I understand these are somewhat universal in their hole placement, and LED locations in later machines. I'm in the process of designing a replacement board. I have the basic schematic of it done, I just need to come up with a footprint for the board.
Any help would be appreciated.
Reply 2 of 9, by jdgabard
wiretap wrote on 2021-01-11, 02:05:
They vary from case to case. There is no universal size or hole placement. I have maybe 15 or so MHz displays, and all are different.
Ok, for some reason I thought they were somewhat universal. Thanks for the info.
Reply 3 of 9, by Sphere478
I would love to work with you on designing a bay insert for newer computers that adds a turbo button and mhz display along with key lock. Is that what you are trying to do?
I have ideas that may be of help. But little to no experience with 3d model building or gerber rendering. But I know some other people who may be able to help on those fronts.
Sphere's PCB projects.
Reply 4 of 9, by Sphere478
In general I think many of the displays were around 0.5” if I remember correctly. Also, many of them had a bunch of jumpers on them for programming the two displayed speeds. So what, three leads?
I think a modern version should be 888 not 188
Reply 5 of 9, by jdgabard
The bay insert is exactly what I had in mind. An easy way for people to convert ATX cases to fully support AT motherboards.
As for the design, I’ve pretty much have the board design done. Just need to tweak a few things. The design I’ve gone with is based on a Microcontroller. And would allow simple adjustment through a couple of tactile switches. I am planning on ordering a few boards in the next few weeks.
For the bay insert, I’ve got a basic design done. I just need to get the boards and a key-lock switch in to get the final dimensions. For the turbo switch I’m planning on going with a standard 8x8mm Lock switch with a 3d printed plunger. The cover is a snap in design.
I’ll post some photos in a bit.
Reply 6 of 9, by jdgabard
Here is what I have worked up so far.
112.48 KiB
74.93 KiB
131.94 KiB
136.44 KiB
Reply 7 of 9, by jdgabard
Sphere478 wrote on 2021-01-17, 08:20:
If you have any input on the design, I'd be happy to hear it.
Reply 8 of 9, by Sphere478
Have you considered using a 3 digit Dc voltage meter on the 12v rail with a potentiometer run through a voltage stabilizing Device like a precision voltage reference? (Not sure if that’s how those things work) but you turn the dial to vary from 000 to 999
You could cut the display lead for the decimal.
Reply 9 of 9, by Sphere478
I think a very needed feature is a heavy duty AT power supply switch like a 1”x1” rocker. And to make it stable the insert should be a box that screws into at least the first four screws cause you’ll be pushing it all the time.
All these atx cases need power switches for these AT power supplies and even the adapters for atx power supplies do as well.
