First post, by kuenzign
According to Compaq's official Service Quick Reference Guide, the Compaq Portable III has 4 BIOS revisions:
Revision   Odd ROM Number   Even ROM Number   Size
K 106778-002 106779-002 16 KB
N.2 107824-001 107825-001 32 KB
P.2 109737-001 109738-001 32 KB
R.2 109737-002 109738-002 32 KB
I was able to find dumps of Revision K and Revision R.2, but I was unable to find dumps of Revision N.2 and Revision P.2. My Compaq Portable III has Revision P.2, which can be seen in the attached image below. I would like to archive this revision since I haven't found it anywhere, but my MiniPro TL866CS programmer is unable to dump the chips. I believe that this is because the chips are Microchip 27256 EPROMs, which use NMOS technology unlike their counterpart the Microchip 27C256, which uses CMOS technology and can be dumped by the MiniPro. Please correct me on this if I am wrong.
Does anyone know how I might be able to dump these chips? Additionally, does anyone have Revision N.2 so that all BIOS revisions can be archived and preserved?
    204.71 KiB
Reply 1 of 6, by Horun
Gently pull one side of the label off and make sure what chip is under (if you have not already) and post what it is.
It is possible to read them using a PCI NIC with rom socket on a proper board and Uniflash or other ROM software since they are fairly small.
On another note see this: https://archive.org/details/COMPAQPORTABLEIIICOMPLETEBIOS
maybe you a newer programmer or updated software ? just a thought...
Reply 2 of 6, by kuenzign
Horun wrote on 2021-01-15, 06:00:
I did peel up the label and as stated, the chips are Microchip 27256 EPROMs, which my programmer cannot dump.
That link is the Revision K BIOS. Mine is Revision P.2, which I want to archive for others to have access to, since I cannot find it anywhere online.
I have the latest version of the MiniPro software (for my programmer version), which is v6.85. The software does not support the Microchip 27256, but it does support the Microchip 27C256 (see the attached screenshot below). Attempting to dump when Microchip 27C256 is selected does not work as it is a different chip.
I don't have experience doing something like that. Do you know of some resources that could explain how to do something like that?
Reply 3 of 6, by Horun
In your MiniPro software is there a box to "check ID" for the EPROM ? Uncheck it and try again !
Does the laptop boot up ?
Reply 4 of 6, by kuenzign
Horun wrote on 2021-01-16, 02:10:
Thanks so much! When I unchecked the "Check ID" box (see in screenshot attached below), I was able to read it as a Miocrochip 27C256.
I have uploaded my revision (P.2) as well as the other two revisions that I was able to find (K and R.2) to the Internet Archive here: https://archive.org/details/compaq-portable-iii-bios
If someone has the N.2 revision, it would be great to add it to the archive so that all four revisions can be together.
My machine does indeed work perfectly. I just wanted to archive the BIOS so that others can benefit.
Reply 5 of 6, by Deksor
Well we can add it here as well 😀 http://www.win3x.org/uh19/motherboard/show/1294
Now this page would be better with a photo as well but disassembling such a thing isn't easy I can imagine
Reply 6 of 6, by Horun
Deksor wrote on 2021-01-16, 11:30:
I found a motherboard pictures on "old junk" website but they are in .RIFF format so converted to .JPG. Large image is 3654x2068, Small is 1400x792.
The jumpers are named exactly the same but the connectors are labeled different. Small image attached here
Took the bios files and added all the pictures and upped to the library: http://www.vogonsdrivers.com/getfile.php?file … 8&menustate=0,0
