First post, by seanneko
I've got an NEC PC-9821Ra333 running Windows 98 which I'm trying to install a Voodoo 2 in. I also have some other 3DFX cards (e.g. Rush, Banshee, etc) which I could potentially use instead but would prefer to stick with the Voodoo 2.
For those who aren't aware, the NEC PC-98 is not IBM compatible. It's similar but has a different architecture which means IBM compatible drivers will not work.
The computer has PCI slots so the card physically goes in and gets detected by Windows, but I'm not able to find any drivers which are compatible with PC-98. I tried the regular IBM compatible drivers, but as I expected they didn't work (the computer froze when it tried to access the card).
Does anyone know of a source to find PC-98 3DFX drivers?
