First post, by sniperhgy
I tried to execute the statement "imgmount c windows95.img -t hdd -ide 1m", get the error message "The image must be on a host or local drive.", also tried to add the full path to the iso file. I can make sure the file does exist, could some one teach me how to do it? Thank you.
56.24 KiB
54.86 KiB
The same statement can execute succesfully in DOSBOX SVN - DAUM.
Reply 1 of 5, by _Rob
If you want to run Win9x, and have support for niceties like CD-ROM support, then have a look at DOSBox-X instead. There are instructions on the DOSBox-X Wiki on how to install various Windows version.
Right now, depending on your host system, it can be a bit slow for late era Win9x games, since you need to run with core=normal. But there is active development to improve the dynamic core to allow it to run Win9x which will improve matters.
Reply 2 of 5, by sniperhgy
_Rob wrote on 2021-01-17, 17:18:
Hi _Rob, thank you for your reply, will take a shot on DOSBOX-X, but I still want to know why I can't execute imgmount in DOSBOX ECE.
Reply 3 of 5, by _Rob
If you remove the "-ide 1m" parameter, it should work. I don't know if the -ide parameter is supported by ECE. It is not listed on the dosbox wiki https://www.dosbox.com/wiki/IMGMOUNT
Assuming the filesystem inside the img file is supported (fat16) and created by DOS 5.0 or later (including Win9x), it should just mount. If it is a newer FAT32 filesystem, you will have to use the "-fs none" option, and specify the disk geometry.
DOSBox-X supports FAT32 and does not need such tricks.
Reply 4 of 5, by sniperhgy
_Rob wrote on 2021-01-18, 08:31:
Finally I give up the DOSBOX ECE and use the DOSBOX-X version, it works well, thank you very much for the suggestion.
Reply 5 of 5, by Yesterplay80
If SVN doesn't support it, then ECE doesn't neither. Else I would have mentioned it in the additional features.
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
