First post, by rain_nr
Hi, I’m building a few retro computers, to test my GPU collection, and I wanted to share with you what I got. My target is to have 4 to 5 testing rigs, to check any VGA card (I have about 80-90 for now) or other hardware I already have, and I will have in the future. I would be grateful for any tips you guys have, and share with me 😀
I have dozen of PC, many 486, lot of socket7, few 286 and 386. But I’ll start with one most important to me right now. This one is for testing any AGP 8x card and lower, on Win XP environment. I choose Socket 462 as a base, and this one is supposed to be fastest 462 I can build. Current spec are:
MB: Gigabyte GA-7VT880
CPU: Athlon XP 3000+ (333FSB)
RAM: 4GB Kingstone PC3200
GPU: Primary is GF4 Ti4200 AGP 8X, but I've thinking about GF4 Ti4600 or another overkill for this spec: Radeon HD3850. Nevertheless this is my test rig, so it will get many GPU's 😉
PSU: Chiftec CFT-600-14CS
I know that RAM is a bit overkill, but testing in 3dMark2001 showed that there is a little progress (marginal) in comparison to 2GB PC2700. Also, I’m already waiting for Athlon 3000+ 400FSBm to match RAM bus, and new 4GB Geil PC3200. In future I ‘would like to buy Athlon 3200+. In the matter of motherboard, a choose this one because of Dual-Channel, and overall spec. I have also ABIT NF7-S2 and NF7-S2G, MSI Delta2 Platinum and a few more 😉
Sorry for my English.
....na c*** kłamałem w CV o języku....
Reply 1 of 9, by matze79
4Gb is no Overkill 😀
Nice Build!
specially if you also run Windows 7 32bit.
Reply 2 of 9, by Munx
Motherboard with KT880 chipset? Nice. Not something you can come across often. The fastest Socket A chipset if reviews from the time are to be believed.
My builds!
The Underdog - The budget K6
Reply 3 of 9, by mastergamma12
Nice rig, I got the Abit version of that board.
Reply 4 of 9, by chrismeyer6
That is a fantastic Socket A build. Once you get it all finished up it'll be quite the speedster.
Reply 5 of 9, by nd22
Very nice system you got there! Without a doubt once you got an Athlon XP 3200 in it will be the second fastest socket 462 system possible! The Athlon XP 3200 will be sufficient for testing any GPU up to Geforce4 and Radeon 8000 series if you go with 1024*768 resolution or Geforce FX and Radeon 9000 series if you crank up the resolution and details!
How much RAM is actually recognized by the board? In my Abit KW7 only 3.25gb out of 4gb is "seen" by Windows! I completed 49 out of 50 tests on a wide variety of socket 462 platforms - form VIA KT400A to nforce2 ultra 400 - and never encountered a situation where more than 2gb would be required!
Reply 6 of 9, by rain_nr
Thanks guys!
It's time for a little update 😊
I got my new Athlon 3000+ 400FSB and I also put Gail PC3200 4GB instead of Kingston, and Pentagram QC-80 Cu cooler. So everything looks a bit nicer inside 😊 I just need to work on some cable management. Second change is returning to IDE drives instead of SATA, purely for practical reasons. SATA connectors on the board where making problem with longer card, for example Radeon HD3850 and GF4 Ti4600.
And know about performance. This is my 3rd revision of the rig, and I have some interesting results on different cards. The test rig was:
Rev1
MB: ECS K7VTA3 KT333 V5.0
CPU: Athlon XP 2500+
Ram: 2GB PC2700
Rev2:
CPU: Athlon XP 3000+ 333FSB
Ram: Kingston 4GB PC3200
And current Rev3.
CPU: Athlon XP 3000+ 400FSB
Ram: Gail 4GB PC3200
I started from my GF2 and GF4 cards, on 3dMark2001SE, on WinXP SP3. What I can see, is that on slower card like GF MX, the gain was marginal. For example:
1. InsideTNC GF2 MX400, w/64MB
a. Rev1: 2911
b. Rev2: 2939
c. Rev3: 2941
2. Unknown GF2 MX400, w/64MB
a. Rev2: 1346
b. Rev3: 1348
3. InsideTNC GF4 MX440, w/64MB
a. Rev1: 3896
b. Rev2: 3983
c. Rev3: 4023
4. ProLink GF4 MX440, w/64MB (this is the highest gain in my MX family)
a. Rev1: 4890
b. Rev2: 5302
c. Rev3: 5585
But when we look at better cards, all the result had really improved:
1. Palit GF2 PRO, w/32MB
Rev1: 4418
Rev2: 4803
Rev3: 5065
2. ProLink GF2 Ti, w/64MB
Rev2: 5014
Rev3: 5293
3. MSI GF4 Ti4200 8x, w/128MB
Rev1: 8146
Rev2: 9137
Rev3: 10068
4. MSI GF4 Ti4600, w/128MB
a. Rev2: 10605
b. Rev3: 11983
But I have 2 anomalies. The PNY GeForce4 MX 440 with AGP8x, is definitely slower on Rev3 config. On Rev2 it had 3650 points, and now 3315. That is more then 300 points less. And another one is the same card, but from MSI, and this one is down from 3745 to 3666. And unfortunately both my GF4MX on AGP 8X, are slower to theirs brothers on AGP4x. But probably is because their slower clocks on GPU and memory.
For example:
MSI GF4 MX440 8x, GPU 261MHz, Memory 64-bit DDR 64MB and 159,8MHz got 3666 points.
InsideTNC GF4 MX440, GPU 270Mhz, Memory 64-bit DDR 64 and 166,5MHz got 4023 points.
nd22 wrote on 2021-01-21, 08:48:
Yep, i'm waiting until one 3200+ shows up on my sight, and testing will start again 😀
The board on POST screen shows 3670016kb, WinXP in DxDiag 3584MB.
Reply 7 of 9, by mastergamma12
rain_nr wrote on 2021-01-21, 11:36:
Thanks guys! It's time for a little update 😊 I got my new Athlon 3000+ 400FSB and I also put Gail PC3200 4GB instead of Kingsto […]
Thanks guys!
Rev1
Ram: 2GB PC2700
Rev2:
And current Rev3.
a. Rev1: 2911
b. Rev2: 2939
c. Rev3: 2941
a. Rev2: 1346
b. Rev3: 1348
a. Rev1: 3896
b. Rev2: 3983
c. Rev3: 4023
a. Rev1: 4890
b. Rev2: 5302
c. Rev3: 5585
Rev1: 4418
Rev2: 4803
Rev3: 5065
Rev2: 5014
Rev3: 5293
Rev1: 8146
Rev2: 9137
Rev3: 10068
a. Rev2: 10605
b. Rev3: 11983
For example:
Seeing that GeiL ram makes me kinda sad, I have a 4 dimm kit of that (well in 512mb) and 1 or 2 of the sticks died out of nowhere.
Reply 8 of 9, by rain_nr
Well, Geil sticks look fantasic inside, mostly by maching colour with MB.
And now I'd like to present my blesing and my curse. I just can't get it work on this machine. And i haven't yet tested it on any other. Working just fine until I install any driver and restart. Always BSOD. I tested 14 diffrent drivers with AGP HotFix, and Omega drivers also. No luck. I'll try on diffrent machine later.
Reply 9 of 9, by rain_nr
I don't know what happen but I there is some strange HW problem. I was testing the Ati 9800XT i i Was unable to properly install driver, it happened before so i Was prepered to reinstall WinXP. Normally it Was good solution. But during installation i get IRQL_NOT_LESS_OR_EQUAL BSOD error. So my first thought was that the VGA card is faulty. But i put perfectly good Ti4200 and the result was the same.
Same issue I had with another GA-7VT880, before i killed it by putting a faulty CPU.
So for now I'm running a MSI K7N2 Delta2 Platinum. Same CPU, Radeon 9800XT and everything is OK for now.
PS, I checked ram with MemTest+. It is ok.
