Dos Trouble
First post, by ThunderPhoenix
I have just started using DOS box and I am trying to play Quake 1 on it. Can someone help me with mounting a file so i can play the game.
Reply 1 of 12, by keenmaster486
Clearly c:\DOSgames does not exist
World's foremost 486 enjoyer.
Reply 2 of 12, by ThunderPhoenix
It's what I am naming my file that has Quake
Reply 3 of 12, by xcomcmdr
You have better options to play Quake : QuakeSpasm, Darkplaces, GLQuake, WinQuake...
Reply 4 of 12, by hawkeyefxr
Read this with great interest as i an struggling with it as well. On a PC i got a game to load and run, but i'm dammed if i cn get a game to run on my Mac.
Reply 5 of 12, by keenmaster486
ThunderPhoenix wrote on 2021-01-20, 07:15:
That's a nonsensical statement. Is that a directory (folder)? There is no such thing as a "file that has Quake"
Reply 6 of 12, by creepingnet
Here's how DOSbox works in laymans terms.....
First things first - you'd need to mount the folder with the DOS Games in it so DOSbox sees it as drive c:\ - it instructs you to do so at first start.
You type something like this....
mount c /users/user/dosgames/
substitute the /users/user/dosgames/ with the file path from your home directory to where the files are stored.
Then C:\users\user\dosgames would become your drive c:\ (assuming it exists) -
then type c:
this will take you to the C:\ drive you "mounted" (actually your directory of DOS games)
then type in cd\quake and type "Quake" and it should boot right up. AT that point it works just like real MS-DOS/PC-DOS/FreeDOS/DR-DOS on actual hardware for the most part. If you want to add and remove files, you can use the commands inside DOSbox or better yet, just copy and paste games to and from the folder you are mounted to.
~The Creeping Network~
Reply 7 of 12, by drosse1meyer
hawkeyefxr wrote on 2021-01-20, 17:44:
As mentioned in this thread, you're better off using a port for your platform and copying over the relevant game files as required.
Reply 8 of 12, by ThunderPhoenix
creepingnet wrote on 2021-01-20, 20:07:
Here's how DOSbox works in laymans terms..... […]
then type c:
It is saying that "this makes the directory d:\dosprogs act as the C: drive inside DOSBox. The directory has to exist."
Then I type in C:\users\user\dosgames like you said replacing user with my computer account. and it is saying illegal command.
Reply 10 of 12, by Pierre32
Like keenmaster486, I have to assume you're talking about a directory (aka folder) called DOSgames.
If you have created a directory on C:\ called DOSgames, when you open DOSBox the command should be exactly as you attempted in your screenshot:
mount c C:\DOSgames
If that's not working, one of these steps has not been done properly. Perhaps you can post a screenshot of your C:\ drive in Windows Explorer?
Reply 11 of 12, by xcomcmdr
Do you have the right to access C:\DOSGames ?
Reply 12 of 12, by hawkeyefxr
Thanks for the rep[lys, i have all straightened out now. I forgot to put "users" in the path to the games folder.
