First post, by Yohokaru
Hi! At the beginning I must say your website has already helped me in many issues, but for this one I couldn't find an answer, so maybe we will find one 😁
I'm using the Daun DOSBOX with the Glide support - 2013 version I suppose. I'm trying to run Polish version of Screamer Rally. I mounted the drive and the CD with -t cdrom and -ioctl switches.
Game installs correctly, with the help of this forum I was able to get through setup.exe [cycles=10000], but when I'm trying to run the game, I encounter this screen
I tried to crack the game, I found this file called CRACK-SR.EXE. However, when i try to execute it with crack-sr -strt3fx.exe, program says it couldn't find the file, like in screen. Running as admin, full control of files, nothing works
Any ideas folks?
