First post, by Mamba
Hello,
I remember that for the MSI pro266td master lr there was a modded bios with full raid support.and 48bit lba.
I am not able to find it anymore, can I ask you to send me a copy if possible?
Reply 1 of 7, by Horun
You can still DL them thru archive org. The only file that does not DL is the hacked RAID driver....
http://web.archive.org/web/20030921173143/htt … -9105/index.htm
IF you cannot get the BIOS files let me know....
Reply 3 of 7, by amijim
Hello Vogons , next week i will revive my msi 9105 board just to flash to this bios.Is there any chance anyone might have saved a compy of the drivers.thank you
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
Reply 5 of 7, by amijim
Hello Vogons, I would like to ask you if anyone has saved the modded raid drivers and can send them to me or inform me how can I mod them by my self. Thank you.
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
Reply 6 of 7, by Mamba
Horun wrote on 2021-01-21, 02:05:
Any clue on where to find the hacked driver?
Reply 7 of 7, by montey
I've got this board with the modded BIOS 1.31b. I dumped it with award winflash.
If i remember correctly, this is the BIOS for the RAID Verison of the board (Master-LR). My MS-9105 lacks support for RAID (Master without "LR") but the BIOS runs flawless.
Hope it helps!
250.96 KiB
MS9105V1.31b.zip
1008.73 KiB
10 downloads
