First post, by Maxx1234
I have successfully built this card:
https://github.com/sbelectronics/emsflashboard
http://www.smbaker.com/8-bit-isa-ems-board-flash-disk-board
https://youtu.be/rj1CxmtXPWM
I have also successfully compiled the EMS driver (SBEMM) following the author's instructions (attached SBEMM.EXE).
For Bill of Materials, Component Placement and Configuration please check the attached files.
Default Configuration for EMS (Port Addres 260h, Window Address E000h, Window Size 64K)
SW1.1: OFF
SW1.2: OFF
SW1.3: OFF
SW1.4: ON
SW1.5: ON
SW1.6: OFF
SW1.7: OFF
SW1.8: ON
SW2.1: OFF
SW2.2: OFF
SW2.3: ON
SW2.4: ON
SW2.5: ON
SW2.6: OFF
SW2.7: OFF
SW2.8: OFF
Does anybody know (or make out from the schematics) the complete DIP switch combinations
for Bank Register Port Address and Window Address Configuration?
Also, does SW2.8 really controls the Page Frame size?
Any help would be appreciated....
Reply 1 of 6, by Maxx1234
After some trial-and-error, I came up with the following settings:
1. Page Frame Address Configuration (SW2.1-SW2.5)
C800h ===> ON-OFF-OFF-ON-ON (Valid only when SW2.8=on)
D000h ===> OFF-ON-OFF-ON-ON
D800h ===> ON-ON-OFF-ON-ON (Valid only when SW2.8=on)
E000h ===> OFF-OFF-ON-ON-ON
E800h ===> ON-OFF-ON-ON-ON (Valid only when SW2.8=on)
2. Page Frame Window Size (SW2.8)
64K ===> OFF
32K ===> ON
The settings were verified with CheckIt Pro v1.1.
The EMS driver works fine when Page Frame Address is D000h/E000h and Page Frame Window Size is 64K.
When Page Frame Address is C800h/D800h/E800h and Page Frame Window Size is 32K and the EMS driver is loaded:
- The Page Frame Window Size is misreported as 64K
- The driver fails to load or produces errors.
Any suggestions?
Reply 2 of 6, by BloodyCactus
well, the ems page must must be 64kb. thats what the official EMS specifications say, so it cant be less, so the driver probably assumes that amount.
--/\-[ Stu : Bloody Cactus :: http://kråketær.com :: http://mega-tokyo.com ]-/\--
Reply 4 of 6, by Maxx1234
BloodyCactus wrote on 2021-03-09, 15:29:
AFAIK, the page frame size was laxed with the LIM EMS 4.0 specifications (unless my memory fails...).
Indeed, there is no option in the driver (which is directly derived from the lo-tech EMS driver) for a 32K window size.
Nevertheless, it would be convenient to use a reduced-size page frame window, so as to free more UMB space for
other uses (maybe someone with programming and technical knowledge would be able to look up at the available
source code and modify it...)
Reply 5 of 6, by Maxx1234
weedeewee wrote on 2021-03-09, 16:48:
Cool !
Could you possibly add a battery to the card when used with sram to get a sorta flash disk ?
This board was designed to also serve as a flash disk - just use Flash instead of SRAM chips
and set the two jumpers accordingly (more info is provided on S.M. Baker' site).
Reply 6 of 6, by weedeewee
Maxx1234 wrote on 2021-03-09, 17:14:
Yes. I read that.
adding a well placed diode and a battery would turn it into persistent EMS memory 😀
