First post, by DNSDies
Just a weird idea I had, but would it be possible to put an interposer board on a CPU socket with 2 additional CPU sockets, and be able to have, say, a switch that prevents vcc to one of the CPUs so you could pick which CPU you're using before powering on the computer?
Like, say I wanted a Super Socket 7 machine with a Pentium 100mhz AND an AMD K6-III 450mhz, and with the push of a button, I could swap CPUs without opening the case.
Or say I had a motherboard that supported a 386 and 486 CPU socket, and wanted to have a way to isolate the 486 CPU via an interposer PCB and a switch that would physically disable the multiple VCC pins.
Would this work, or would the address/data lines and various other pins need to be separated as well?
Because I don't think it's possible to find a 200-300 input switch. But a 4-6 input switch? That's much easier.
This is a dumb idea.
Reply 1 of 3, by mkarcher
DNSDies wrote on 2021-01-26, 18:41:
Just a weird idea I had, but would it be possible to put an interposer board on a CPU socket with 2 additional CPU sockets, and […]
Don't try to take a unused CPU off the bus by just disabling the power pins. It won't work, as the ESD protection diodes from the data pins to VCC will cause excess leakage and power the chip. Instead, you need to correctly power both CPUs, but have the unused CPU in bus hold or float mode where the CPU does not drive bus pins.
Reply 2 of 3, by adalbert
Doing that with bunch of clicky relays would be funny. And probably wouldn't work, but whatever 😁
This is just a joke, but I wonder if some relatively cheap digital switching IC could be used. 386s and 486s are not too fast, so maybe? That is, if we would like to really isolate these CPUs. If full isolation is not required, then it certainly would be easier.
AT(X)Anything: a modular DC-DC PSU for old PCs (open hardware)
Reply 3 of 3, by DNSDies
So, drive the BOFF pin and HOLD and AHOLD to their respective active voltage levels via a physical jumper or switch, and that might do the trick, huh?
Might be neat to design such a thing. It's a niche market, but it could also be used to provide voltage regulation to normal Socket 7 motherboards to use newer K6s, or allow a standard 486 socket take lower voltage DX models.
I'd pay $150~ for something like that.
adalbert wrote on 2021-01-26, 21:07:
imagine the noise though.
