First post, by Intel486dx33
My sound blaster pro 2.0 is picking up noise and static and some sounds dont play thru PC speakers but play only in internal motherboard speaker ?
Do I need “Set-mix’ loaded ?
What settings do I need in autoexec.bat ?
First I want to know if I have the right CDROM cable ?
Does anyone know the Pin-out of the CD-In connector ?
CD-In
Pin #1 = ?
Pin #2 = ?
Pin #3 = ?
Pin #4 = ?
I dont see anything about this in the manual.
Reply 1 of 3, by Caluser2000
It just takes a standard CD audio cable with that type of connector and suitable connector to fit in to the CDRom drive itself. These cables are a dime a dozen.
You don't show us the cable you have and I am not psychic.
Reply 2 of 3, by SodaSuccubus
I'm pretty sure Sound Blaster Pro series cards are supposed to be a bit noisey naturally, no? That's just kinda the reality of early Creative Labs cards, especially if you have the internal speaker routed. Aging caps may play a part too.
Did they ever make shielded CD audio cables? I know some of my quieter cards pickup a bit of noise when the CD drive is active but it's usually inaudable under the sounds of the game. Best fix is to turn it down in the mixer program.
Reply 3 of 3, by Intel486dx33
I found the info on the pin-out in the back of the manual
CD-In
Pin #1 = G
Pin #2 = R
Pin #3 = G
Pin #4 = L
I commented out the line in autoexec.bat for the Set-mix settings.
Music CDROM disks play clear with no static.
The game “Wing Commander” plays with some static.
Most games sound good.
Creative test and demo songs and demo MIDI/.Wav files play good.
If I plug my speakers directly into the CDROM drive the audio is clear.
Its when I plug my speakers into the rear jack of the sound card that I get static and distortion ?
It is strange because I have a couple sound blaster pro 2.0 cards and they both suffer from static and distortion.
But the AWE64 cards I have play perfectly.
So maybe I just have a bad driver. But I have some original installation disks I can try out.
Its just some games that sound terrible.
