First post, by Miphee
I have the chance to buy this CPU for a good price but the seller doesn't have a mainboard to test it, I don't have one either.
How reliable are these? I know it's impossible to tell but I know that socket 462 Athlons are very sensitive to cooling failures, one second without a cooler with an Athlon 462 and it's toast. What about the slot A variations? Are these reliably built like the slot 1 Intels?
Reply 1 of 14, by mwdmeyer
Should be fine. The motherboards are harder to get working though....
Reply 2 of 14, by Miphee
mwdmeyer wrote on 2021-01-27, 21:13:
Yes, probably won't get a board anytime soon.
Reply 3 of 14, by PD2JK
If you damage these, something really went wrong. Struck by lightning, power surge, exploded power supply, extraordinary temperatures, et cetera...
The voltage/multiplier couldn't be set higher without a GFD, which required opening the CPU package.
Do you have some 50mm fans laying around? 😀
Oh and check if the L2 cache makes contact with the heatspreader. To my experience, the paste can be a bit misplaced. They should have used pads because of the 2mm space between.
Be careful when disassembling, it's quite challenging if you're planning to.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 4 of 14, by Miphee
PD2JK wrote on 2021-01-27, 21:24:
Nothing to test it with so that will have to wait.
But if you guys say that it's a reliable design then I'll buy it because it's my first slot A CPU. 😀
Reply 5 of 14, by PD2JK
Congrats! Welcome to the club. Now on to fetch a nice board.
I'm working on a tormented Abit KA7; about 30 caps blown, missing heatsink, missing SMD capacitors, few bend pins IN the slot (for crying out loud)....
Reply 6 of 14, by Miphee
PD2JK wrote on 2021-01-27, 21:36:
Thanks!
I haven't seen a slot A board on the local auction site since I started collecting hardware in 2019. It's like the socket 8 board for me. Plenty of Pentium Pros, zero boards. Well, I'm patient. 😀
Reply 7 of 14, by Miphee
Got the K7, fingers crossed!
Reply 8 of 14, by chrismeyer6
Very nice. I really hope you can find a good slot A board. Slot A is fun to play with.
Reply 9 of 14, by Miphee
Thanks, my source told me that he hasn't seen a slot A board in years.
I'll try to post and ad locally and see what happens.
Reply 10 of 14, by mwdmeyer
Yeah hard to find. I have been lucky to have two although the first one died very quickly. The second one I think is an OEM compaq one but works well. The fan is very loud on the CPU, need to replace it.
Reply 11 of 14, by Miphee
So it's missing a fan I presume? Or were they sold with a heatsink only?
Reply 12 of 14, by Horun
Miphee wrote on 2021-01-30, 02:02:
My only K7 Slot A (K7-600MTR51B-C) came without any heatsink or fan originally, uses same as a P2 H/S fan AFAIK. It looks just like a Pentium II without the heatsink+fan.
Have had it for years along with the Asus K7M board and still works using a P2-dual fan P2/slot A cooler.
Good luck finding a board but Asus, Abit and Gigabyte made some good ones...
On the socket 8: found a good board and included cpu+ram for ~$70 US back in June, is a DFI board. They do not come up often but sometimes get lucky 😀
Will keep my eye out for soc8 board for you.
Reply 13 of 14, by Miphee
That's a pretty good price for a socket 8 board.
I curse the day I sold my Compaq Deskpro! I didn't really care for the Pentium Pro back then.
It's ironic because now I have 2 Pentium Pro cards for an IBM 704 but not the server itself. 😁
(not my images, I only have 1 of the cards populated)
Reply 14 of 14, by Miphee
Horun wrote on 2021-01-30, 02:54:
That's very kind of you. Your board looks almost like one of my slot1 boards. I had to remove the green chipset heatsink because the CPU didn't fit in the socket with that on. 😁
