Leading Edge Model M MP1676L
First post, by rick12373
I just found this in the basement at work. I found some info here https://arvutimuuseum.ee/th99/m/I-L/30486.htm which says it is an 8088 IBM clone. This is way before my knowledge goes with PCs. I really only started tinkering with hardware with my 486 back in the day. Is that a CGA card? I don't have the monitor but it looks like I could connect to a TV with composite? Where the heck does the keyboard plug in? Could this be good for running games from this era?
    182.82 KiB
    213.28 KiB
    88.57 KiB
    121.38 KiB
    172.97 KiB
486 DX4-100 (overdrive)
16MB 72-pin SIMM RAM (2x8MB)
1MB Diamond Speedstar Pro VLB video card
SB 16 Value CT2770
AOpen VI15G Socket 3 Motherboard
HDD/FDD VLB controller card
Reply 1 of 20, by rick12373
Found the keyboard. Plugs in at the front.
    172.45 KiB
SB 16 Value CT2770
Reply 2 of 20, by Horun
Nice ! Yes could be CGA and yes should be able to a TV but not sure. Can you open it up and get some pictures ?
Reply 4 of 20, by rick12373
OK. I have opened the beast up. Here are some pics. I need to take it to my office at home to try and connect an old TV to it. I think I might have some kind of component to VGA adapter box at home as well. I wonder if that would let me connect it to a VGA CRT?
    282.52 KiB
    316.17 KiB
    332.13 KiB
SB 16 Value CT2770
Reply 5 of 20, by jesolo
I have the rebranded version called the Sperry HT PC.
More info here in my original post: Sperry HT PC (XT) - model 3070-03
and here: http://www.vcfed.org/forum/showthread.p ... ion-wanted
It does utilise CGA graphics and you therefore require a CGA/EGA monitor or similar device capable to read those signals (if you use the 9-pin connector). The composite out should work on any monitor/TV set that can accept NTSC signals.
I was fortunate enough to find mine with the case and monitor, but no keyboard (would be nice to pair mine with an original 83-key keyboard), but for now I'm using a switchable XT/AT keyboard.
PS: The "M" stands for Mitsubishi. Later on Leading Edge/Sperry used Daewoo to manufacture their later models and hence the name change to "Model D".
Reply 6 of 20, by rick12373
jesolo wrote on 2021-01-28, 21:26:
I have the rebranded version called the Sperry HT PC. More info here in my original post: Sperry HT PC (XT) - model 3070-03 and […]
Thanks for that information. I think the monitor may still be in the basement at work here. We are slowly clearing it out and it is a huge area. I did see some monitors down there I will go and have a search. I see yours has the branding "Sperry" on the front. I will keep an eye out for that although I assume it might have had a different monitor.
I found a box of 5 1/4 floppies with games on!
SB 16 Value CT2770
Reply 8 of 20, by rick12373
Had another look and apart from some more old 5 1/4 disks I did not find the original monitor. There are quite a few down there but they are all from a newer era than what I am looking for. There are some areas I can't get to yet until some more of the junk is cleared though, so maybe. I did find a few Windows 95 era laptops/PCs and pentium motherboards with the CPU in as well. I would rescue them from being thrown away but I already have too much of that stuff stored.
SB 16 Value CT2770
Reply 9 of 20, by jesolo
rick12373 wrote on 2021-01-28, 22:24:
As I recall, the Leading Edge monitor does not look the same than the Sperry branded one.
When you do go down there, look for any older monitor with a 9-pin (DE9) connector (as opposed to the 15-pin VGA connector).
If you can't locate the original Leading Edge one, then maybe you can find a suitable replacement.
Just be cognisant of the fact that MDA, CGA & EGA all used the same connector.
EGA monitors can accept CGA signals as well, but not all MDA monitors can.
Most of the older MDA monitors had the three RGB pins missing.
Reply 10 of 20, by rick12373
No, they were all VGA CRTs. I suppose I will have to use the composite connector and a TV.
SB 16 Value CT2770
Reply 11 of 20, by rmay635703
Those round MDA connections with the appropriate adapter cable are moderately rare.
Not really sure why the round ttl/ analog hookups existed but most commodore/magnavox screens of the era had them
Reply 12 of 20, by rick12373
I just realized that when I had the case open I didn't look for a CMOS battery. I should have done that to see if it was leaking. Need to open it again to see if I can see it.
SB 16 Value CT2770
Reply 13 of 20, by rick12373
Bad news. I did not see a leaking CMOS battery, I don't think there is any problem there. But I tried turning it on and I could hear the fans spin up etc but then there was a pop and an electrical burning smell. All the fans were still spinning after that but I quickly pulled the power anyway. I opened it up again and can't see what it was that went out. I am not good at electronics repair so I doubt I would be able to fix it anyway. I would like to though. So I am not sure what to do with it now. I would sell it on ebay but as the thing weighs so much I am not sure that is worth doing.
SB 16 Value CT2770
Reply 14 of 20, by rdipaolo
rick12373 wrote on 2021-01-27, 23:27:
This exact model was my 2nd personal computer, after having built a ZX81. The model M was a great machine for its time.
I might be willing to buy your model M with all accessories as I am a retired electrical engineer and can repair whatever is wrong with it ( the burnt item, whatever it is).
I don't have much $$ these days, living on retirement savings and disabled veteran compensation, but make me an offer that can cover shipping (USPS or UPS only please) plus what you want and I will seriously consider it. It would ship to the Ketchikan Alaska area where I now live.
Thank you very much for considering my inquiry!
Very best regards,
Roger
Reply 15 of 20, by rick12373
rdipaolo wrote on 2021-04-10, 21:04:
This exact model was my 2nd personal computer, after having built a ZX81. The model M was a great machine for its time. […]
Very best regards,
Roger
I would be open to that. I will try and figure this out next week. I kind of wanted to take the 5 1/4 drive out to put in my 486. Do you already have a spare 5 /14 to put in it? I don't have to keep it though, I could get another one from somewhere else. I am in Idaho, not super far away, but I bet the shipping will still be a lot. Did you want the keyboard as well? That also weighs a lot, the heaviest keyboard I have ever come across actually.
SB 16 Value CT2770
Reply 16 of 20, by rick12373
As rdipaolo has not replied to me I was wondering if anybody wants this or parts from this machine. I also have a couple of really old IDE controller cards that I found and a couple of boxes of 5 1/4 floppy disks a lot of which seem to have old games on. Preferably somebody near here that can pick them up, although that is less likely. I am in South East Idaho.
SB 16 Value CT2770
Reply 17 of 20, by MrGatoGrande
rick12373 wrote on 2021-04-21, 15:41:
Hello there,
Did you ever get this sold? I have another Model M but with some parts not working so I'd be interested in yours.
Reply 18 of 20, by rick12373
MrGatoGrande wrote on 2022-10-14, 22:52:
Hello there,
I have some of the cards from it still. Although the CGA video card was swapped in to another older computer for someone else, but I now have the CGA card from that machine instead. I used the 5 1/2 floppy in one of my machines but I think there are some other cards from it still in my storage. I will have to look if you are interested. Don't have the motherboard though, I am pretty sure it was toast, so it was tossed.
SB 16 Value CT2770
Reply 19 of 20, by MrGatoGrande
What about the case and the PSU? I'd be interesting on getting those since my PSU seems to be failing on and off. If I can get those I'll buy the rest of the cards from you as well. Also the keyboard.
