First post, by Sphere478
So I just discovered these were a thing.
And that you can put plop boot manager on them. Awesomeness, what else can You do with them? They work in basically any isa computer right?
Can clover work on them? Or is it too big?
Sphere's PCB projects.
Reply 1 of 6, by Cyberdyne
And XTIDE universal IDE BIOS for using large drives in old computers. And you can even put a minimalist DOS in rom, but there are many limitations in the open source implementation. I have not get into commercial ROM-DOS.
Reply 2 of 6, by Sphere478
Cyberdyne wrote on 2021-01-28, 12:23:
How does the hard drive thing work? Does it sense the hard drives on the motherboard and allow the larger size cause it loads it instead of the system bios?
Yeah, I was actually just wondering about a dos os on rom 🤣.
Reply 4 of 6, by debs3759
Sphere478 wrote on 2021-01-28, 12:40:
It installs itself after the system BIOS has loaded, and takes control of int 13h for hard drives.
Reply 5 of 6, by Cyberdyne
I really fight the urge to necropost this CGA game thread. Well it is time to modify additional motherboard scavenged 32pin Flash EEPROMs to 28pin to use them with my LAN cards. And start to experiment.
