First post, by mike_canada
I'm using DOSBOX 0.74 for Linux.
I made an application in QuickBasic and assembly that sends out a chunk of data at 57Kbps to hardware connected to the serial port. Yes I own an internal authentic UART in my computer and linux can access it perfectly fine.
As I send out and expect data in return, the linux console window I executed DOSBOX from gave me the following responses:
DOSBox version 0.74Copyright 2002-2010 DOSBox Team, published under GNU GPL.---CONFIG:Loading primary settings from config file /root/.dosbox/dosbox-0.74.confMIXER:Got different values from SDL: freq 11025, blocksize 352MIDI:Opened device:noneSerial1: Opening ttyS0Serial2: Connected to 127.0.0.1Serial3: Connected to 127.0.0.1DOS keyboard layout loaded with main language code US for layout usMAPPER: Loading mapper settings from /root/.dosbox/mapper-0.74.mapSerial1: Errors: Framing 0, Parity 0, Overrun RX:2 (IF0:0), TX:0, Break 0Serial1: Errors: Framing 0, Parity 0, Overrun RX:2 (IF0:0), TX:0, Break 0Serial1: Errors: Framing 0, Parity 0, Overrun RX:2 (IF0:0), TX:0, Break 0Serial1: Errors: Framing 0, Parity 0, Overrun RX:58 (IF0:0), TX:0, Break 0
But the ones that concern me are the Serial1 Errors.
This is my dosbox config for the serial ports:
serial1=directserial realport:ttyS0 transparent:1 txdelay:1 rxdelay:1serial3=nullmodem server:127.0.0.1 port:8000 transparent:1 txdelay:1serial2=nullmodem server:127.0.0.1 port:8001 transparent:1serial4=disabled
The first one is the one I use in my application. Serial3 and Serial2 are for other debugging purposes of which one helps make a network run in DOSBOX. I have other code for the networking that is executed before-hand. I should make that as a post in itself.
So anyways, I tried various settings for my real serial port.
I tried these three lines separately:
serial1=directserial realport:ttyS0 transparent:1 txdelay:1serial1=directserial realport:ttyS0 transparent:1 txdelay:1 rxdelay:1serial1=directserial realport:ttyS0 transparent:1serial1=directserial realport:ttyS0
and /dev/ttyS0 is my serial port for linux.
and everytime I do I/O with the serial port, I keep getting the overrun errors.
Is there a way to fix this? Maybe there's something I can do at the linux level that I'm currently not aware of? Or maybe there's a way in DOSBOX to fix this?
Any idea?
