First post, by Ripthron
I googled a little bit and noticed that in this forum some people had this model, so I decided to ask here
I found one relatively for cheap, so I ended up buying. When I turned on the device I noticed that the display looked a little strange, the information was only readable if I looked at it from strange angles.
I looked for videos on YouTube and I saw people making videos of the module with strange angles.
Now comes the question: Do I have a module with a broken display or does it have a really bad display? Any help will be grateful!
    295.88 KiB
Reply 1 of 16, by yawetaG
That looks like someone adjusted the contrast wrongly on the display. Check the manual (available from Kawai USA) to see whether it can be adjusted (it will either be a knob on the module or a setting in the menus).
It can also mean a failed display, although normally when they fade over time you don't see much at all... In that case you'll have to replace the display unit (en hope Kawai didn't use a custom display).
Reply 2 of 16, by Ripthron
yawetaG wrote on 2021-02-01, 08:17:
Yeah, that was my first assumption, I looked in the manual and I really don't see any mention of display brightness or contrast .
I contacted the seller and he said that he has an option to adjust the display, but he was not specific and indicated the same manual that I saw.
Reply 6 of 16, by Ripthron
sf78 wrote on 2021-02-02, 10:52:
Open it up and see if there is this type of trim pot that could adjust the brightness.
I thought that could be it and I asked the seller if it didn't have an internal slider/knob/pot and he said no, it was through the panel.
He also said he would ask a friend who has a similar device how to change the display contrast.
I'll wait for today, if I don't get an answer I'll open the device and look for a pot / slider / knob.
Reply 8 of 16, by yawetaG
Ripthron wrote on 2021-02-02, 12:51:
I thought that could be it and I asked the seller if it didn't have an internal slider/knob/pot and he said no, it was through t […]
Just be careful because I've seen similar types of pot to adjust settings that when improperly adjusted can seriously screw up how a synth module works...
Reply 9 of 16, by Ripthron
sf78 wrote on 2021-02-02, 13:30:
It could also be a solder joint or capacitor issue. Better to open it and check everything anyway.
I opened it and didn't see anything that could be used to adjust the display.
I couldn't remove the secondary pcb, but I looked with the camera and didn't see anything that looks like a trim pot or a dial. I doubt it is between the display's pcb and faceplate
yawetaG wrote on 2021-02-05, 21:11:
Don't worry, I'll leave it the way it is. At least it's working well.
    1.19 MiB
Reply 10 of 16, by sf78
Ripthron wrote on 2021-02-06, 14:31:
Yeah, I wouldn't worry about it too much. You'd have to remove the whole lower PCB from the case to examine the solder joints anyway. It could be a power issue with the display unit or a voltage regulator somewhere, but without measuring it's just random guessing. If it works and the display doesn't bother you too much, I'd ask for a (partial) refund from the seller if it was sold as working.
Reply 11 of 16, by Ripthron
sf78 wrote on 2021-02-08, 10:35:
I'm starting to think that the display is just really bad.
    790.18 KiB
Reply 12 of 16, by Salient
The Kawai Gmega uses a generic Hitachi HD4478 based 16x2 display afaik. Any of those from AliExpress will probably do. Maybe you'd have to fiddle a little to align it (don't know if the screw holes match) but it should be possible.
Did the same twice with both my Roland RA-50's 😀
Reply 13 of 16, by sf78
Judging by these videos:
https://www.youtube.com/watch?v=kkFE1025hEw
https://www.youtube.com/watch?v=7IsOGGJK5xY
The display should probably look like that. There are also those videos you mentioned that show contrast problems.
Reply 15 of 16, by Ripthron
Salient wrote on 2021-02-08, 18:44:
Thanks for the info. I probably ask someone to replace it
sf78 wrote on 2021-02-09, 10:02:
Judging by these videos: […]
Yeah... it could be the camera angle too...
Rawit wrote on 2021-02-09, 14:23:
You are using the correct power supply?
Not exactly, it's from Kawai but has a lower amperage, it's the one the previous owner used. I tested it with the MT-32 power supply, which has specifications similar to the Kawai GMEGA psu, but unfortunately it didn't change anything.
I already bought a new one, I'm waiting to be delivered, but I doubt it will change anything.
