First post, by cnpr
hello all
I have been looking for a power that will power with these specs:
intel 866 cpu
gigabyte 6bxc
384 mb of ram
dvd drive
gotek floppy emulator
NVidia GeForce 4200 ti
voodoo 2 in sli
creative labs awe 64 gold
usb 2 card
20gb hdd
i well aware that the 5v rail may be a issue and i have been look at the corsair power supply but the one i saw are 20a and I'm concerned it will not be enough. will the corsair ones be enough for this setup?
Reply 1 of 2, by Sphere478
I wouldn’t expect that to give most modern normal sized power supplies any issue. Why are you conserned?
In general your power usage is proportional to the amount of heat you are generating. So how big are your heat sinks? 😉
Sphere's PCB projects.
Reply 2 of 2, by Doornkaat
The system is likely going to draw less than 100W on all power rails combined. Clean, stable 20A on +5V is going to be fine.
