First post, by ultra_code
Hello VOGONS,
I was just wondering. I've been ever so slowly overclocking some Socket 478 CPUs on my Asus P4C800-E Deluxe, and I've noticed with all of the Northwood and Prescott CPUs, I'm unable to go above 1.6V Vcore. I've read in a couple of older forum posts scattered throughout the web that it this was an issue with Prescotts and with the motherboard recognizing the CPU as Prescott and limiting the max setting in-BIOS to 1.6V, even though there are options for higher values, although this issue is also apparent with the highest-end Northwoods I've tested. I'm in the middle of testing my two Willamete CPUs, and they obviously consume a lot more power, so the lowest setting so far is 1.75V; don't know if Asus put in place a Vcore wall somewhere for these guys, though.
In the case of the Prescott and especially Northwood CPUs, this wall has been a bit of a pain, since I know I could push these CPUs harder if it weren't for the supposedly artificial Vcore limitation on this motherboard, as my current cooling setup (old Titan water-block fitted to a modern loop with a 280mm rad and a Corsair pump+res combo) easily keeps these CPUs cool. Apparently this issue annoyed enthusiasts of the day with the original P4C800, which prompted Asus to I guess address the issue and allow for greater Vcore settings (https://www.anandtech.com/show/1133). However, which the latest 1024.001 beta BIOS, such feature is not available, and thus a hardware Vcore mod, not to mention a Vdroop mod, is my only option.
I was wondering if anyone knew why Asus decided to limit Vcore in such a way with these boards, and also for any other P4C800-E Deluxe owners out there, were there any BIOS releases that allowed you to go over 1.6V Vcore in-BIOS? Thanks!
Builds
Reply 1 of 6, by majestyk
I can think of two reasons for this - assuming ASUS did this intentionally.
1. To protect certain CPUs from being damaged by any Vcore too far out op specs.
2. To protect the Vcore voltage regulators on the ASUS board.
Since Prescotts had high power consumptions (> 130W), when Vcore (U) is incresed, the respective DC current (I) rises also, the Power (P= I x U) drawn from the onboard voltage regulators would probably excced the maximum values ASUS designed the boards for when Northwood was just released.
This would mean they implemented a power limit by setting a voltage barrier at 1.6V.
I therefore assume that 2. is the case because mainboard vendors don´t care about the lifespans of CPUS so much, but try to avoid damages to their own products.
Reply 2 of 6, by ultra_code
majestyk wrote on 2021-01-31, 15:22:
I can think of two reasons for this - assuming ASUS did this intentionally. […]
Not a bad idea. Although then it begs the question - why didn't Asus just design a better VRM that could handle higher Vcore settings, like their competitors probably did? Why do they do so much to design such a nice looking BIOS and a feature-packed board, go out of their way to make the board a OCer-friendly board, yet skimp out on the VRM? Something isn't right.
Builds
Reply 3 of 6, by majestyk
Did they believe a max. overvolting 0f 0.2V would be sufficient for Prescotts?
On the other hand: This was the time, when the "capacitor plague" was raging everywhere. My own ASUS "P4C800 Deluxe" had issues with the caps in the VRM circuits after a few years.
Supposed they knew that there was a lot of trouble ahead because of failing capacitors and they knew that those caps would fail the sooner the more users would be allowed to overvolt (due to more power consumption -> more heat -> shorter cap life). And with Prescotts entering the market these effects were even stronger.
Then the BIOS limitzations could have been an emergency break.
Reply 4 of 6, by ultra_code
majestyk wrote on 2021-01-31, 16:22:
Did they believe a max. overvolting 0f 0.2V would be sufficient for Prescotts? On the other hand: This was the time, when the "c […]
On the other hand: This was the time, when the "capacitor plague" was raging everywhere. My ASUS "P4C800 Deluxe" had issues in the caps in the VRM circuits after a few years.
Supposed they knew that there was a lot of trouble ahead because of failing capacitors and they knew that those caps would fail the sooner the more users would be allowed to overvolt (due to mure power cunsuption -> more heat -> shorter cap life). And with Prescotts entering the market these effects were even stronger.
Hmm... unfortunate, in any case.
Then the remaining question is, are there any BIOSes for the P4C800-E Deluxe that ever had uncapped Vcore settings?
Builds
Reply 5 of 6, by majestyk
Best chance would be a version before they added the Prescott CPU-IDs.
Reply 6 of 6, by ultra_code
majestyk wrote on 2021-01-31, 16:31:
Noted.
Also, would it be possible to find the offending hex values that limit Vcore in newer BIOSes using the older BIOSes as a reference and remove that limitation? I'd think a software solution is way easier to back-track on than a hardware fix for the issue.
Builds
