First post, by voodoo5_6k
I thought, this might also be of interest in the Sound section of the forums. I'll spare you most of the story around it (you can read it here), just write about the setup... Also, all of the credit goes to @Cloudschatze, I just adapted it to my setup and wrote it down, so it is easier to find.
First, a little background. Roughly five years ago, I read about Cloudschatze's interesting setup, which includes a split channel configuration of 2x CM-64 (2x32 voice=64 voice polyphony) and 2x SC-55 (2x24 voice=48 voice polyphony), here and here.
Key is a MIDI interface that is capable of MIDI routing, or at least channel splitting/muting. Cloudschatze used a Music Quest MQX-32M, and then connected two daisy-chains of SC-55 + CM-64 to the two MIDI-out ports. Channel splitting (odd/even) configuration is applied via autoexec.bat. Then, SysEx messages would configure the MIDI devices for either SC-55 or CM-32L playback.
The result is a CM-32L cluster with 64 voice polyphony, and an SC-55 cluster with 48 voice polyphony.
I wanted to adapt this for my setup. But with a little twist... well, simplification 😉
What is that supposed to mean? First, I use my MIDI modules with three PCs. Therefore, the setup has to be as transparent as possible. Second, I didn't want to mess around with SysEx messages. OK, so how to get it done?
I purchased the current model of the MOTU micro express (https://motu.com/products/midi/micro_usb). It is a 4-in/6-out MIDI router, and can hold eight user-programmable presets. Using their ClockWorks software, the device can be configured as needed, and then can be used as a stand-alone device, with no further need for a USB connection (except for power). I created three presets, one per PC. In each preset, one specific MIDI-in port is routed to the five MIDI-out ports on the back. On the output side*, I have set a filter to mute the even or odd channels, respectively, for each pair of modules. As a result, CM-32L #1 only gets to play the odd channels, CM-32L #2 the even channels of the complete MIDI signal. Same for the SC-55's. The X3MB receives the unmodified MIDI signal. As all outputs receive the MIDI signal all the time, it is also great for testing different MIDI modules in games. I just power on all devices and then switch the desired audio output to the sound card.
(* It is important to do that on the output side, as otherwise the respective filter would change the MIDI signal entering the micro express, with no connected device having access to the full signal.)
45.22 KiB
Here you see the SC-55 pair playing the Sam & Max - Hit the Road intro. SC-55 #1 plays on the odd channels, SC-55 #2 on the even channels. Success!
412 KiB
Now, recap...
  1. Configure a MIDI interface to split channels across at least two MIDI-out ports (odd/even).
  2. Connect one MIDI module to one MIDI-out port (at least two modules).
  3. If there are more modules than MIDI-out ports, apply SysEx messages for configuration of the daisy-chains or connect a MIDI patchbay between the MIDI interface and the modules.
  4. Enjoy 😎
END OF LINE.
Reply 1 of 10, by Kahenraz
I can understand the usefulness of this for a General MIDI device, but the CM-32L is based on the MT-32, which has a known polyphony. What is an examples are there where the composer wrote music for the MT-32 without taking this into consideration?
Reply 2 of 10, by BloodyCactus
does it actually renumber the channels on split, so you said odds, evens so like 1,3,5,7,9 becomes 1,2,3,4,5 on device 1? the screenshot of the sc55 displays seems like this is not the case, so your not actually doubling the channel count, so seems kind of pointless. you could just run a midi through box and get the same result without all the messing around and get all the voices from both boxes instead of half the voices from each box... (and I could be totally misinterpreting yours setup making this reply pointless 🤣!)
My emu soundengine has a dedicated poly out through mode which lets you double the channel count transparently, its very nice. but then you can get a roland soniccell and have 128 voices of polyphony and make everything else look tiny 😀
--/\-[ Stu : Bloody Cactus :: http://kråketær.com :: http://mega-tokyo.com ]-/\--
Reply 3 of 10, by voodoo5_6k
Kahenraz wrote on 2022-04-27, 12:30:
I'm not aware, and I'm just doing it for the fun of it (and peace of mind) 😀
BloodyCactus wrote on 2022-04-27, 13:03:
Well, one MIDI channel can be assigned more than one track. Consequently, more than one "voice" can result from a single channel. 16 channels are the limit for one MIDI hardware link. So, as a composer, you'd assign all your tracks to the 16 channels. But if the resulting output exhausts the MIDI device's polyphony, another hypothetical 16 channels won't change that (again, the MIDI hardware link is limited to 16). So, by splitting the channels (odd/even), two MIDI devices with a given polyphony have less voices to generate (individually), and therefore, their individual polyphony limit has been effectively circumvented (as now two MIDI devices share the work intended for one). The line outs of both MIDI devices are then combined in my audio chain (with a 3u rack mixer).
END OF LINE.
Reply 4 of 10, by Kahenraz
I would like to have a setup like this. The challenge is finding an exact match for the existing SC-55, since there are so many different firmware revisions. Most sellers don't know how to display this information, and many units on auction don't even come with a power cable for them to test with.
Reply 6 of 10, by RetroGamer4Ever
imi wrote on 2022-04-27, 16:05:
I still don't quite get what the benefit of this is ^^ is there any realistic scenario (apart from complex music making) where you'd run into a limit without doing this?
Quite a few games have MIDI that occasionally surges past the polyphony of the classic MIDI modules that were used to create the music. Only the last of the premium MIDI hardware modules can fully play such music. That's why software MIDI is so great, as you can easily get 128-256 and beyond with modern hardware.
Reply 7 of 10, by Kahenraz
RetroGamer4Ever is correct. The Yamaha MU50 and Roland SC-88 are probably the best options for maximum polyphony using a single module. The SC-55 though has a very unique and, in my opinion, the best sounding instruments out of all the early General MIDI devices. But it has a number of other issues, including the aforementioned limited polyphony, which is present in games that, although era-appropriate, you might not have realized are clipping or dropping notes, such as in Warcraft II.
The SC-88 in SC-55 compatibility mode is the closest alternative using genuine vintage synthesizers, but it doesn't sound exactly the same. Even the SC-55 itself has a small range of differences depending on which hardware and firmware revision is used.
One interesting thing to note about Warcraft II is that the mastered soundtrack is actually a combination of the SC-55 and SC-88. I don't recall where I read this exactly; it has been quoted somewhere on this forum.
Reply 8 of 10, by imi
RetroGamer4Ever wrote on 2022-04-27, 16:09:
do you have any examples by any chance? I'd be interested to hear the difference it makes.
Reply 9 of 10, by Kahenraz
imi wrote on 2022-04-27, 19:47:
See here:
Significant differences with certain MIDI files across Roland synthesizers
An analysis of Warcraft 2 MIDI music on Roland synthesizers
I put together a lot of very detailed samples there that demonstrate what it sounds like to run out of polyphony during playback. The artifacts are very subtle and will differ between synthesizers, firmware revisions, and sometimes even the same synthesizer when the same MIDI track is played in a loop. In practice, these variations normally go unnoticed, as any first-time listeners will have no other point of reference. The differences only become apparent when listening to the same track when played between synthesizers.
Reply 10 of 10, by RetroGamer4Ever
Many of the Quest Studios (Sierra) MIDI files bump past the limit of the 90's MIDI hardware modules. I've seen them go into the 100s, on occasion. That's why the X2GS is a no-brain buy for a retro gaming build, because it can handle much of the old game music, with it's polyphony of 81. The next model from Dreamblaster will have even higher polyphony and handle anything from the golden days of MIDI gaming.
