First post, by retroguy83
Hello,
I'm having a small problem running games from dos.
Well, it's basically as the subject says. I can run windows based games fine, but theres no audio support when I run the games in dos.
In the setup of "Under a killing moon" it tries to autodetect the sound card, but finds nothing.
The card shows in hardware management as SB PCI (WDM).
Is there anything I can do?
Thank you in advance.
Retroguy83
