First post, by melo
Hallo,
I wonder if someone of you owns the card you see in the picture below and would like to help me in order to build a cable.
I've read in this forum that is not impossible, someone built his own cable for an IBM sound card; but of course I need pin-out from someone that has my same card with its cable and some patience to trace pins with a tester.
The card can also work to handle SCSI but I'm mostly interested to have the sound features working.
