First post, by Jackhead
Im getting parts at the moment for building a Super Socket 7 System. Sure i can go to pentium 3 like asus P2B but i like to keep it on Socket7.
The ATX formfactor has many good features to rebuild something with mixed new parts. Im not focus on timeline perfect build.
More a mix of best from past and today. The project will start soon and i like to share the progress (maybe problems) here.
So my idea/setup for start will be:
- Asus P5A SS7 Rev 1.04
- 512 MB RAM
- Be Quiet Power 9 400W ATX
- AMD K6 3+ 450MHz (OC @ 600MHz)
- Matrox G400 MAX
- Matrox m3D PCX2
- Roland MPU-401AT + Yucatan FX
- Soundblaster AWE32 3980 (Yamaha DB50XG on board)
- Delock mSata to IDE with 32Gb MLC mSata
- Pioneer Slot in IDE
- Gotek with FlashFloppy
- Cuplex Aquacomputer waterblock with ULTITUBE D5 100 PRO and Alphacool NexXxoS V.2 ST30 360 for CPU
- Case: Phanteks LUXE black
The plan is to boot dos 6.22 or win98SE from different SDs i can easy switch on the front. For DOS Games software downstep the cpu and cache.
For Win9x Games max and anything with SS7.
At first is the fun building anything up.
First pictures follow soon. Hope this will be funny project and i cant wait what it looks like at the end. Hope you guys also like it.
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - AMD A5x86 X5 ADZ 133MHz @160MHz - 64MB RAM - CT2230 - GUS ACE - MPU-401 AT - ET4000W32P
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI @ 66MHz PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 1 of 29, by Jackhead
First Step Voodoo 5500 replaced the Fans and heatsinks with noctua 5v, add ram cooler
629.68 KiB
693.89 KiB
I notice that the push option cools better as pull on this pcb. So GPU is ready. For the heatsinks i use arctic silver 2 comp clue.
Reply 2 of 29, by bloodem
Pretty nice retro PC you've got there. 😀
Although, I myself would not use a Voodoo 5 5500 on SS7, but that's just me. Then again, I generally struggle to find a use for Voodoo 5 5500 😀
I do have a recommendation, since you already tuned your Voodoo card: add two heatsinks on the back of the VSA-100 chips (in those little squares surrounded by capacitors on the back of the card). It will further help with temperatures and possibly prolonging the card's life. However, make sure that you avoid causing a short circuit 😀
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 3 of 29, by Jackhead
Add some heatsinks on the GPUs back, thanks for the tip! Used some cooling tape to prevent a short.
1.45 MiB
Some more parts arrived:
The attachment IMG_0786.JPG is no longer available
1.91 MiB
1.81 MiB
1.28 MiB
    1.71 MiB
Reply 4 of 29, by dulu
- Do you know what case will you use ? old? new?
- Are you planning to use a side window panel?
- Are you planning to make a lightning inside the window
- What about coolant colour?
Reply 5 of 29, by Jackhead
Yes, i decided to use the Phanteks LUXE (https://www.phanteks.com/Enthoo-Luxe.html) in black. RGBs are also planed for the window side.
Reply 6 of 29, by dulu
And how much did you pay for waterblock? I`m looking for block with this type of mounting for socket A with no results. There is only one in my country - Swiftech MCW5002-A but it looks terrible.
Reply 7 of 29, by Jackhead
dulu wrote on 2021-02-14, 16:14:
50 bugs, was lucky catch.
Reply 8 of 29, by matze79
What’s the gain of cooling a K6 with water ?
Reply 9 of 29, by bloodem
Street cred? (if we're talking about a street populated with tech nerds). 😁
I myself love the idea of such an exotic cooling for an infamously slow platform... (nerd alert?!)
Reply 12 of 29, by Jackhead
Got the case today so the fun starts! First installed the PSU, the MB and the Radiator. Still waiting for Fans and the water cooling screws.
The pump with water reservoir will find a place under the drive bay tomorrow.
1.23 MiB
1.23 MiB
1.46 MiB
Reply 13 of 29, by Jackhead
Got the Ultitube D5 100 pump today. Fits perfect! I choose the PWM D5 because i dont have any USB or even software to control the pump.
So i will use a small PWM controller from noctua to adjust the voltage.
1.32 MiB
Also stocked my CT3980 with 2x 16MB Samsung 60ns RAM , tested on win95 and dos sb diag, works perfect.
815.99 KiB
Reply 14 of 29, by dulu
Jackhead wrote on 2021-02-17, 17:11:
Don't you think d5 is overkill for this setup? 😮 There is only one block and one rad. I think dc-lt would be enough.
And think twice if you really want to connect d5 with the fan controller. I did exactly the same once and ended up burning it. But my pump was dcp 2.2 which has a power consumption of 6.5W, and yours pulls 37.
Of course 37W is a maximum power consumption and you will rather reduce your RPM, but just don't make my mistake 😁 Check the maximum power load declared by the manufacturer of the controller and check that the transistor does not overheat too much 😀
Reply 15 of 29, by Jackhead
The controller has 12V max 3A so 36W, should be ok? Because i dont run max. You used same NA-FC1 controller ?
But i think the Aquacomputer D5 used 12V line over molex and the PWM is only for adjustment (signal).
618.38 KiB
Reply 16 of 29, by dulu
No No. Dont remember the manufacturer. I remember that the maximum ldeclarated load was 9.5W. The controller was connected to a dcp pump (6.5W) and 2 fans, 1W each, which gave 8.5W. The controller burned up despite the fact that the pump and fans did not draw as much energy, because they were turned to about 7V. I believe that noctua is a reliable company, but to be calm - watch the temperature of the transistor. It'll probably be hot, that's normal. For comparison, mine melted the casing : )
Reply 17 of 29, by Jackhead
i will see but thanks for the point. Will have a look on it. Overkill i dont know. I will run the K6 3+ 450MHz @ 2.2V 550MHz first. I read he get really hot on 2.2V and i look than how far i can go. Maybe it go above 600+. And as i mentation before the cuplex was the first block and the waterloop is not really perfect like blocks today so i will see. I will get the connectors tomorrow. Was even hard to get G1/8 11-8 .. the rest is G1/4 11-8.
That was the Fan installed on the CPU when i got it. A PAL 6035 with papst fan, Ultra noisy ^^ Anyway fun project for me.
1.55 MiB
Reply 18 of 29, by bloodem
Looking very good! 😀
As another advice, you might want to ditch the SD card approach. You'll find that overall it's much slower than a real disk (and it has frequent hiccups/stutters).
If you're looking for ultimate speed, a 128 GB SSD + SATA to IDE adapter is probably the best approach (although, even this one can have issues on certain platforms).
Another fast and pretty quiet storage solution is a late model IDE HDD (250GB) and limit its capacity to 128 GB.
Reply 19 of 29, by Jackhead
Ok first tests are pretty good. Need to install OS but anything is dry and water flow well 😀
I jumped the k6 III+ 450 to multi x2, 2.2V for 600MHz and let it run some minutes on bios.
Sure this is nothing to say its stable, but temps loock good so far around 30°.
Still need to do some more cable management, but for today im pretty happy with the result.
1.59 MiB
1.71 MiB
1.1 MiB
