Printing
First post, by Newbie
Hello,
dosbox is great. I heard about an unoficial printing function. I would need it. How can I get it and include it into dosbox, so that the printer prints it when I select Print in a dos app?
It would also be ok if it created a kind of dump that can be printed later.
Thanks!
Reply 1 of 1, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Search !!! I think that there are some old binaries with printing support available here on Vogons. If not or if you need printing in the newest DOSBOX, then you have bad luck (well, you can have a look on printing patch on sourceforge and if you are an experienced programmer you can try to apply it to the newer sources...).
Mirek
