First post, by Thrust
Thrust
Offline
- Newbie
Hi!
I have been trying to get Dosbox running under Armbian Buster OS and the computer is Pine64. This is the minimal installation, and there is only command line mode available. After I installed all dependencies that were needed, I got Dosbox somewhat working. The problem is, that when I try to type anything, it gives some "random" letters, and finally does not respond at all. I tried to read ./configure file, but I don't know where to start. Could you help me please?
