First post, by ruthan
Hello,
i need help, i enjoyed playing Lords of magic SE - unpatched 3.0.1 - its running fine on Win 10 even without dgVoodoo now- actual Gog version, but in my only actual save, 1 character broke.. cant move, because of some bug, he has 0/0 movement points, instead 15/15, all other character stats looks fine. I searched for some cheats, but i did not found anything as character editor or something like that, but did not fount anything. There is only cheat for 1000 movement points per turn, its not proper solution.
Unofficial patch is not solving it.
Because is only 1 parameter, im hoping that some Hex magic, would be maybe able to fix problem. I just need to edit 1 or 2 variable that is character movement points i needs to be changed from 0 to 15 value. Character name is Geran is this string could be found in save file.. but after that are only some typical Hex values unknow to me, maybe someone would be able to decipher them and maybe there is not some special CRC to prevent saves modifications.
Here other character "Glurin" was class etc with proper value (12/12) - i could help to fix it.
How bug could occur, i have some ideas:
- removed some artifacts before it god bugged, but later wasnt able to find any compatible artefact for this character which would modify movement
- maybe ended battle stuck with some frozen spell, which block character movement.. im not sure about this battle, but i saw such spell in game
- i could be some in game feature - curse, which i dont understand.. but nowhere see some indicator for it, but i saw in between spells some dispel spell..
Here is save file:
https://www.dropbox.com/s/3qy073irrl3318v/zaloha?dl=0
The attachment 2021-03-04 09.52.54.jpg is no longer available
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 1 of 1, by ruthan
Solved it was curse, so dispel worked.. if im not missing something is just pure bad design, there is not indicator of any active curse on character etc..
