First post, by Tempest
I have an odd problem. I'm trying to put an GeForce MX420 (Asus 5187-1531 6mnh1) into a GX-260 because this card has S-Video out which I need. The system is working fine with an NVIDIA 32MB VGA AGP Video Card (CN-01E200-4457) in it, but when I try and put the Asus into it it suddenly won't boot. Is the Asus card compatible with this system? They're both AGP slot cards so I can't see why they wouldn't work.
--- AtariProtos.com ---
For when excellence and burnished fineries need to gently visit the warmth of your tablery
Reply 1 of 21, by darry
Tempest wrote on 2021-03-05, 00:39:
I have an odd problem. I'm trying to put an NVIDIA GeForce GT 420 (Asus 5187-1531 6mnh1) into a GTX-260 because this card has S-Video out which I need. The system is working fine with an NVIDIA 32MB VGA AGP Video Card (CN-01E200-4457) in it, but when I try and put the Asus into it it suddenly won't boot. Is the Asus card compatible with this system? They're both PCI Express cards so I can't see why they wouldn't work.
Do you mean a Dell OptiPlex GX260 when you say Dell GTX-260 ?
Also do you mean 32-bit 33MHz ("legacy") PCI, because that's what a Dell OptiPlex GX260 has in addition to an AGP slot (as opposed to PCI Express slots)?
It's unfortunately not uncommon for newer legacy PCI video cards to not work in older PCI-equipped systems .
EDIT : Added clarifications
Reply 2 of 21, by Tempest
Yes I'm sorry. I mean a GX260 and it's an AGP slot not an PCI Express slot. I wasn't thinking when I was typing.
Reply 3 of 21, by darry
Tempest wrote on 2021-03-05, 06:07:
No worries, just making sure I understand .
That NVIDIA GeForce GT 420 is probably PCI, though, or did someone actually make an AGP variant ?
Reply 4 of 21, by red-ray
AFAIK there is no thing as an AGP GT 420, only PCIe and PCI. Post a picture of your card.
I suspect your card is an MX420, see https://ithardwaregroup.co.uk/5187-1531-hp-nv … -graphics-card/
Reply 5 of 21, by Tempest
Yes that's the one. I got the original description off an eBay auction because I only had a part number. Sorry about that.
Any reason it wouldn't work though? The system literally won't boot with it installed.
Reply 6 of 21, by red-ray
Exactly what is the CN-01E200-4457? What is it's PCI ID? If you don't know then the [PCI Bus] panel of my SIV utility should tell you.
Once we know exactly what the other card is we can compare the AGP specs of the two cards.
It would also help to know what the post code is or at least the how the system beeps when it fails to post.
Reply 7 of 21, by Tempest
Here are both cards. The top one won't work, but the bottom does. They're both AGP. (Sorry for the link, but it won't let me post a pictures if it's not https).
http://atariprotos.com/temp/cards.jpg
Reply 8 of 21, by red-ray
Again exactly what is the CN-01E200-4457? What is it's PCI ID?
Reply 9 of 21, by Tempest
red-ray wrote on 2021-03-05, 13:41:
Where would I find that? As you can see the card doesn't have many markings.
It appears to be this one: https://www.amazon.com/DELL-NVIDIA-VIDEO-CN-0 … 5/dp/B00B871FA8
Reply 10 of 21, by red-ray
red-ray wrote on 2021-03-05, 13:17:
Tempest wrote on 2021-03-05, 14:14:
I told you how to find it!
Knowing this would also help.
Reply 11 of 21, by Tempest
I missed that post, I'm sorry. I'll try and run it now
It doesn't boot period. The power light goes on (green, not orange), but I get no beeps or visual on the monitor. The hard drive doesn't seem to access either.
Reply 12 of 21, by red-ray
You said it did post with the CN-01E200-4457 installed and it's the CN-01E200-4457 I asked about!
You have also failed to specify how the system beeps when it fails to post with the MX 420 installed.
If you yet again fail to provide this information I will stop trying to help you.
Reply 13 of 21, by Tempest
red-ray wrote on 2021-03-05, 14:54:
Sorry yes, I got the two numbers mixed. up. I'll get the PCI ID number momentarily. I need to transfer your program over to my system.
With the MX420 installed I get no beeps what so ever. There's no activity in the system period other than the power light.
Reply 14 of 21, by Tempest
Ok I'm not sure if I'm reading this right but it says:
Bus Numb-Fun
1-00-0
IRQ
16
Vendor-Dev-Sub_OEM
10DE-0150-002E10DE-A4
Class
VGA Controller
Vendor and Device Desc
nVidia NV15 [GeForce2 GTS/GeForce2 Pro][GPU-0]
I'll take a picture of the screen as well.
http://atariprotos.com/temp/siv.jpg
Reply 15 of 21, by red-ray
So the working card is a NV15 [GeForce2 GTS/GeForce2 Pro], the specs are https://www.techpowerup.com/gpu-specs/geforce2-gts.c797 and the problematic one is a NV17 [GeForce4 MX 420], specs https://www.techpowerup.com/gpu-specs/geforce4-mx-420.c777
Given they both are Architecture Celsius I would expect the MX 420 to work and wonder if it's faulty, does it work in any other systems and how sure are you that it's OK? Where did it come from?
Reply 16 of 21, by Tempest
red-ray wrote on 2021-03-05, 16:01:
It could be faulty, I have no idea where it came from or any way to test it in another system. If it should just work then I guess it must be bad.
Reply 17 of 21, by drosse1meyer
Do you get any beep codes?
Reply 19 of 21, by drosse1meyer
red-ray wrote on 2021-03-06, 23:17:
Tempest wrote on 2021-03-05, 14:56:
drosse1meyer wrote on 2021-03-06, 22:54:
I feel it's wise to read existing posts before posting!
Great thanks
@OP - I too have similar issues but with a different Dell. AGP cards that should work otherwise cause problems with POSTing, however in my case I would get 1 long 2 short beep, which means vid card. So it may not be such a stretch to think that Dell BIOSes and/ or their vendor provided mobos are hit or miss with some vid cards.
In my case, I was able to get the card 'working' in a roundabout fashion by installing a PCI vid card, ensure the primary video option was set to PCI in bios, power down, install the problematic AGP card (while keeping the PCI installed), then it would POST fine. Machine booted to windows and I could see both cards in device manager, install drivers, etc.
Note that I only did this to figure out if the 'bad' card was actually working, but I guess you could run such a system for general use if you properly installed drivers and configured multiple display via nVidia's utilities.
