First post, by Bernkastel7734
Hello,
Reccently I got this 486 motherboard. I believe it's Peacock P486DX rev. :D.( At least that's what markings say). It was booting up, untill I connected HDD to that IDE slot. Unplugged HDD and still no boot. Any idea what's going on?
Reply 2 of 10, by Bernkastel7734
Deksor wrote on 2021-03-06, 09:53:
I see a lot of tantalum caps. Can you check the AT connector for any shorts ?
Maybe some of the caps failed right after you used that board ?
Nothing seems to be shorted, sadly
Reply 3 of 10, by Bernkastel7734
Oh, I forgot. Before dead of this mobo I reseated ram, cpu and video card after plugging hdd and it helped, but not for second time.
Reply 5 of 10, by Bernkastel7734
Well, so I need to check that. Is there any possibility that connecting hdd could burn that motherboard?
Reply 6 of 10, by Deksor
Unless you hdd has a major flaw or that you connected it incorrectly I don't think so. You also pointed that it worked better for a brief moment after reseating everything (without hdd connected I guess ?)
Reply 7 of 10, by Bernkastel7734
Deksor wrote on 2021-03-06, 12:43:
Well, this hdd had worked fine with other pc, and if the markings on the motherboard is fine I've connected it correctly. Yeah, the first time I've triend to use it with hdd that method helped. Also, does that matter that this
IDE connector have got all pins?
Reply 8 of 10, by Bernkastel7734
Tried to reseat BIOS chip, also washed it with alcohol. It didn't help.
Reply 9 of 10, by Bernkastel7734
Looked with my infrared camera at that board after switching on the power , and the chip marked symphony sl82c362(that one near IDE connector) is't heating at all. Dunno if it were heating up while that board was alive, but maybe there is a loose joint near that chip.
Reply 10 of 10, by Bernkastel7734
I know it's an old post, but I've tried to use POST diagnostics card with that motherboard. It seems that something killed the bios chip since there is no reading of any POST codes. I just wonder what it could be? The PSU I used was a modern one with suitable ATX to AT converter.
