Unisys Aquanta DM/6 II mb manual?
First post, by Kotu Koylu
Hi.
i could not find aquanta dm/6 II manual?
i have only board wth working condition.
But i need reset sw/ hdd led pins location on board?
Thanks in advance...
Reply 1 of 22, by Horun
Most Unisys boards from mid 1990's are OEM FIC boards (my Unisys CWD5001 and my ELI 46665 are). Can you take a good picture of the motherboards and post it here ?
Most of the old Unisys links are dead, even in Archive.org. Here is one for your board but it is mostly corrupt and the driver links go to long dead FTP site:
http://web.archive.org/web/20001025235606/htt … -2/sysboard.htm
Reply 2 of 22, by vetz
I'd try contacting evasive over on motherboards.org (he is still active there and here on Vogons also through https://www.elhvb.com/), maybe he still has some files:
http://www.motherboards.org/forums/viewtopic. … 115570&start=10
Reply 4 of 22, by Horun
Good work PC Hoarder Patrol ! I found only one decent older Aquanta quick guide (similar to the one inside the case of my ELI466) but was for the DX CWP50051 and it does not have the front panel connections 🙁
If you find any others we should up them to Vogons library for future use...
Reply 7 of 22, by vetz
red-ray wrote on 2021-03-07, 07:33:
I would not trust that site!
Reply 8 of 22, by vetz
When searching around I did find a promotional Aquanta screensaver from Unisys. Haven't installed it, but thought it would be interesting to add here.
    aquanta.exe
    2.05 MiB
    8 downloads
Reply 9 of 22, by Deksor
Can you upload a good photo of your board so we can add it to UH19 ? http://www.win3x.org/uh19/
alternative
Reply 10 of 22, by Kotu Koylu
Deksor wrote on 2021-03-07, 11:50:
Sorry for side-angle.
    156.46 KiB
Reply 11 of 22, by Deksor
The angle isn't a problem (except in extreme situations), we can straighten it however the resolution is quite low 🙁
At least it gives us enough infos to add this board to UH19, but a better photo (even with an angle like this) is welcome !
alternative
Reply 12 of 22, by Kotu Koylu
Deksor wrote on 2021-03-08, 14:49:
Enough?
    1.54 MiB
Reply 13 of 22, by Kotu Koylu
Pentium Pro 150-200mhz cpu support
60/66 Mhz fsb support
2-3-4 cpu clock ratio
4 x72 pin simm ram slot
1 5volt sdram slot
İntel fx chipset
4 pci 3 isa slot (1 isa/1pci shared)
Onboard 2 rs232 / 1 paralel port /2 usb port (usb mouse keyboard not supported)
2 ide /1 fdd connector
Onboard Creative Sound Blaster Vibra 16 CL sound chip (isa pnp)
Gameport
ESC key enters bios boot menu(cd/floppy/hdd)
Phoenix Bios
That is it 🙂👍
Reply 14 of 22, by Deksor
Thank you !
I have added the motherboard here http://www.win3x.org/uh19/motherboard/show/7644
Would you like to dump its bios using uniflash as well ?
alternative
Reply 15 of 22, by Kotu Koylu
Deksor wrote on 2021-03-08, 19:11:
Thank you !
No needed to dumping bios.
Same as this original bios exe(use 7zip to extract)
By the way thanks for collecting mb infos/pics.Good site although poor youtube channel. i think you have a big collection.
But in your channel i see a few videos 🙂👍
    DM6II174.EXE
    156.28 KiB
    6 downloads
    Aquanta DM/6 II BIOS UPDATE FILE
Reply 16 of 22, by Deksor
Well I need to make more videos and make them better, that's true. Now I'm not sure if I'l make them in english ... (some will I guess).
alternative
Reply 17 of 22, by Deksor
I contacted evasive, according to him, the board is an Acer V60X. The acer brand is confirmed by the bios : in the readme file you can read "Acer" being mentioned. Also the acer V60N (baby AT motherboard) looks similar in the PCB color, components and connectors : http://www.win3x.org/uh19/motherboard/show/221
Unfortunately he has nothing else. Maybe Acer V60X rings a bell to someone here ?
alternative
Reply 18 of 22, by PC Hoarder Patrol
Here's a copy of the later (last?) BIOS version for the board, in case you want to add it as well
"Aquanta DM/6 II; CMT6xxx72. Phoenix BIOS V4.0 R5.1 Unisys Ver 1.90 (Self-Extracting Archive). Extract to bootable floppy. (26-Jan-1998 )"
Dm62bios190.exe
156.26 KiB
9 downloads
