First post, by dionb
- l33t
Recently picked up a very interesting device - a Compaq Multibay LS-120 drive, shiny NOS. Wow! Just one problem: how to hook it up to anything else...
Now, there's quite a lot of info available about Multibay II, and lots of devices too, including nice USB 2.0 external cradles. Lovely. But this LS-120 drive is Multibay I. One clear difference is drive height. The Multibay I is around 12.55mm high, where the Multibay II is only 9mm high. So this drive isn't going to fit into one of those cradles. Oh well. However what I'm more interested in, is the other end: I can't find pinouts for the connector, so I can't determine whether it's electrically the same.
Given age of the platforms, I strongly suspect that Multibay I was basically PATA-on-an-SCA-like-connector, where the Multibay II would be SATA-on-similar-connector. In that case it's going to be different and there's no point in buying one of those cradles to cannibalize the actual converter bits.
Anyone have any info on the bus/pinout? Or on ways to get Multibay I talking IDE or USB outside of a 2000-ish Compaq laptop?
