486dx2 Cmos Batteries
First post, by original_meusli
Hello,
I bought a 486 build on eBay for a Christmas present but it has never successfully kept its CMOS settings so every time I freshly boot I need to pop into the CMOS and find my HDD etc. The board is a MV035 486WB.
I thought at the time "it's no problem, it's probably a dead battery", so I ordered some off Amazon and put it in the case, still the same problem. So searching this forum I found an old thread where they said the batteries needed are LIR2032 or LIR2450 and not the DL2032/CR2032 I bought(and the same as I replaced). Could this be the cause of the CMOS settings never saving? (please say yes)
Thanks
Reply 1 of 21, by Doornkaat
Now for a useful answer: The LIR type cells are rechargeable and will be around 3.6V while a CR2032 is non-rechargeable and only has 3V.
The higher voltage may be needed to store settings on this motherboard while the higher voltage charging the CR battery could have already killed it.
I recommend you remove the CR battery before turning the PC on again because it could cause some real damage in the PC from being charged.
Reply 2 of 21, by weedeewee
original_meusli wrote on 2021-03-09, 14:14:
Hello, […]
Hello,
Thanks
again, no.
the Opti 82C602 has an onboard RTC which needs to be supplied by a 3V backup battery.
Check for continuity between pin 55 of the 82C602 and the positive of the battery holder
Do not ask Why !
Reply 4 of 21, by original_meusli
Below is a picture of the MB from the Ebay listing (at work so cant get a new pic). I can't see the OPTi chip anywhere, is the write back chip circled the alternative?
    1.41 MiB
Reply 5 of 21, by weedeewee
That looks more like one of my crappy pcchips m912 boards, actually identical, even has the same version number in the same corner, except for the stickers on the chips.
I've measured on mine, even pulled the label off and, surprise, no chipid engraved, and that chip is different from the opti 82C602.
Neither pin 5 nor 55 are connected to the battery. So it must be another pin. I'll check later.
Do not ask Why !
Reply 7 of 21, by Deksor
It's indeed a PCChips m912 rev 1.7 to be exact.
http://www.win3x.org/uh19/motherboard/show/573
It has actually a UMC chipset. Yours have fake cache though (and yes the bios reports L2 cache but it lies. Run a cache benchmark and you'll see the truth)
If you're motivated enough, you can get rid of the fake cache chips and install real ones though.
Also it's using a standard cr2032 battery 😀
Reply 8 of 21, by weedeewee
Deksor wrote on 2021-03-09, 15:41:
It's indeed a PCChips m912 rev 1.7 to be exact. […]
Deksor, Any idea on which pin of the UMC... (the small chip) the battery is connected ?
original_meusli you could take JP1 off and put it back on... might be a little crusty and is required for the onboard battery.
Do not ask Why !
Reply 9 of 21, by Deksor
Maybe I can do that with my own board but I only have rev 1.4 boards. I hope it's the same.
Also like I said this board uses cr2032 batteries only. If OP used a rechargeable battery, maybe it's just flat because there's no recharging circuit ?
Reply 10 of 21, by original_meusli
Never even heard of fake cache chips, so thanks for letting me know. I am motivated to replace them yes. 😀
Do they need fully populating and do you know the type I need?
Reply 11 of 21, by original_meusli
weedeewee wrote on 2021-03-09, 15:45:
I'll do that as soon as I get home. Its also a standard CR2032 battery in there, none rechargeable. As mentioned it arrived like this and change of battery like for like and this has not fixed it.
Reply 12 of 21, by Deksor
There are different brands, speed and sizes, but they're compatible among all the 486 boards. You can take a look at motherboard photos online and pick a cache chip you like. 256Kb and 15-20NS were the most common. You need a set of 9 chips.
I'd recommend you to install sockets in these spots as well and not just solder the cache chips in place.
Installing a new cr2032 should fix your problems. The old one must be discharged since the 1990's ^^
Reply 14 of 21, by weedeewee
Deksor wrote on 2021-03-09, 15:50:
Well, I just checked the v1.4 board... and battery is not directly connected to one of the big chips 🙁
Do not ask Why !
Reply 16 of 21, by weedeewee
Should measure about 2.5V between ground and that pin
apparently there's an extra diode that drops the voltage.
if the voltage isn't there, check R51 & D7 (near the battery) should measure 3V and 2.5V between ground
the same location on the v1.4 board.
    571.48 KiB
    RTC battery pin pcchips m912 v1.7
Do not ask Why !
Reply 17 of 21, by original_meusli
weedeewee wrote on 2021-03-09, 16:17:
Should measure about 2.5V between ground and that pin apparently there's an extra diode that drops the voltage. if the voltage […]
I'll try that tonight and get back to you with the results. Again thanks.
Reply 19 of 21, by original_meusli
I can now confirm that there is no charge visible between the pins on that chip or any of the other pins on the same side. I assume at this point that its not going to work, but as mentioned its not the end of the world. Now to think about fake cache chip replacment mentioned and see if I can find any break in the paths on the board to cmos chip while I'm at it.
Thanks again everyone for the help.
