First post, by MoG91
Evening Everyone,
I have this Dell XPi that’s in really nice shape. I installed an IDE to SD adapter in it and it’s working great. But I’m really unsure how to get sound working and I’m having trouble finding the neomagic drivers in an unpacked format. I don’t have a working floppy drive in it currently so I can’t just unpack the self extracting exe for the neomagic drivers. As it specifically will only unpack to a floppy. And I have no idea what sound drivers to install. The PC speaker drivers work sort of. But give really crackly audio. Anyone mind giving some advice with this thing? Just for fun I’ve attached a picture of it running. It’s a nice little machine
Reply 1 of 5, by PC Hoarder Patrol
MoG91 wrote on 2021-03-16, 03:51:
Evening Everyone,
Try these- they're self-extracting archives based on these download links
NeoMagic NM2090 - https://www.dell.com/support/home/en-uk/drive … driverid=r18688
ESS 1888 - https://www.dell.com/support/home/en-uk/drive … driverid=r18791
but bypass the 'write to floppy' stage, so they'll extract to either the default location of (where you copy) the archives or you can choose a different location in the 'Extract To' dialog box.
XPICDG.exe
1.02 MiB
37 downloads
xpisaud2.exe
593.7 KiB
44 downloads
Reply 2 of 5, by MoG91
PC Hoarder Patrol wrote on 2021-03-16, 05:38:
Try these- they're self-extracting archives based on these download links […]
Evening Everyone,
XPICDG.exe
xpisaud2.exe
When you run the self extracting archive it actually extracts another self extracting archive that has instructions on using the program to write an image to a blank floppy. Which would be fine if my floppy drive worked! At any rate you gave me an idea to just try to use the newest version of 7zip to extract that exe. And it appears to have extracted! I'm going to try to install the files I extracted and see how it goes. Thank you for all your help!
Edit: I’m up and running now. Everything looks great! Thank you!
Reply 3 of 5, by PC Hoarder Patrol
MoG91 wrote on 2021-03-16, 11:58:
Evening Everyone,
XPICDG.exe
xpisaud2.exe
Glad you got it sorted - by coincidence that's exactly what I had done...downloaded the files from Dell, unpacked them (twice) with 7zip and recompressed the actual installation files as the two self-extracting attachments here 😀
Reply 4 of 5, by darry
Evening Everyone,
XPICDG.exe
xpisaud2.exe
If 7Zip had not worked, a way around the problem would have been to run the floppy self extractor in a virtual machine, have it write to the emulated floppy drive and copy the files from there .
Reply 5 of 5, by MoG91
darry wrote on 2021-03-17, 08:59:
XPICDG.exe
xpisaud2.exe
PC Hoarder Patrol wrote on 2021-03-17, 08:17:
XPICDG.exe
xpisaud2.exe
To be honest I didn’t even try the attachments you gave. I just assumed it was the same thing as on the Dell site. I always forget how great 7Zip is though. It works for so many things. But installing the files in a virtual floppy is a pretty good idea too. I recently learned about using raw disk mode in virtual machines to install OSs so using it for something like that is a good idea too. Thanks again all! And take care,
