First post, by pdmelo
I have a Philips PCD 211 PC (AT 286 12-5 MHz, 2 MB RAM, VGA onboard)
I'm having trouble getting the diskette drive to work. It's a Epson SMD-300 HD model. The BIOS detects a HD diskette drive, the PC boot (DOS 3.1 from the Hard Drive), but when I try to access a diskette I always get read error.
The diskette drive works OK. I've tested it in another system. Reads and Writes.
I've also tried other working diskette drives and get the same result.
Does anyone have any ideas about I am doing wrong?
