AT PSU Switches.
First post, by original_meusli
I have bought a spare AT PSU that does not include a switch. Its not arrived here yet so I have not looked at it properly but I am looking to get a switch for it.
From the picture It has four cables with connectors on the end and I was wondering if this is the correct type of switch to buy?
https://uk.rs-online.com/web/p/tactile-switches/7561408/
Cheers
Reply 1 of 4, by weedeewee
No.
You need a switch that is rated for mains voltage 110/220/240VAC and for the current the psu draws, preferably a bit higher.
and which has these blade connections for easy connection.
Do not ask Why !
Reply 3 of 4, by weedeewee
if it fits your case, that will do, also make sure it's an on/off button not a momentary action button, verify that !
One thing though... Verify you hooked it up correctly before plugging it in ! if you connect it the wrong way, you will blow the mains fuse when you plug in the computer.
Do not ask Why !
Reply 4 of 4, by original_meusli
OK, I will be very careful. Wish me luck. 🤣
