First post, by Deksor
Hi ! I just got a Abit PR5 R2 from a dead board lot and I probably identified the defect.
The attachment IMG_20210318_212209.jpg is no longer available
Here you can see that there's a regulator that's missing (and the other has its cooler missing)
The difference is even more noticeable when comparing with a photo of the same motherboard http://www.win3x.org/uh19/motherboard/show/114
Does anyone have this board ? Can you shoot a high res image of this area ?
Reply 1 of 1, by SSTV2
There are two identical LDO regulators on board, Q5 transistor that's missing should be the same as Q4 😉
