IBM 6x86MX 266
First post, by nnet
Hello, im just trying to run IBM 6x86MX 266. It have 2,5x 83Mhz.
All my motherboard have max 75Mhz clock speed.
Now im trying to make it run with MB PAM-0073I or P/I-P55SP3AV
What type of motherboard shoud i use?
PS: Processor have model number IMB26x86MX-BVAPR266HF i cant find any reasonamble information about it.
Reply 1 of 2, by debs3759
If all your boards have maximum 75 MHz bus, try it at 75 x 2.75 (if that multiplier is available) or 75 x 3. Otherwise you want a Super Socket 7 board.
Reply 2 of 2, by Repo Man11
More than a few Intel HX and TX chipset motherboards had the 83 MHz frontside bus clock. http://www.thg.ru/mainboard/19971201/print.html
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
