First post, by Woody72
My Supermicro P5-XTRA has a pair of transistors clamped to a black aluminium heatsink near to the CPU socket. The heatsink runs extremely hot and I noticed on Amazon that you can get tiny 5v 30mm fans with two connectors, each designed to fit a jumper style pin. Given that the LED headers for power and turbo run 5v, I was thinking of getting one of these tiny fans to permanently blow on the heatsink. Has anyone tried this 🤔?
Modern PC: i7-9700KF, 16GB memory, RTX 3060. Proper PC: Pentium 200 MMX, 128MB EDO memory, GeForce2 MX(200).
Reply 1 of 10, by Warlord
why not just not strip the wires and rewire to a normal molex. Instead of putting strain on the motherboard like that.
Reply 2 of 10, by Sphere478
it might work but those leds take less power than a fan. it's kinda risky in my book I bet those lights are powered by very small solid state switches. though the power led header may just be a hardwire to 5v. you may be able to verify by following traces. if so that may be safe.
at own risk 😀 personally I wouldn't risk it. but if you do, let us know how bad of an idea it was 🤣
Sphere's PCB projects.
Reply 3 of 10, by adalbert
I doubt that LED headers would power a fan, because they have to be current limited (likely through a resistor), otherwise LED would blow up instantly, because by itself it takes unlimited power.
AT(X)Anything: a modular DC-DC PSU for old PCs (open hardware)
Reply 4 of 10, by maxtherabbit
adalbert wrote on 2021-03-22, 19:56:
correct
Reply 5 of 10, by Sphere478
maxtherabbit wrote on 2021-03-22, 20:30:
correct
I've plugged leds into 3v batteries before without a resistor didn't seem to be shorting it. are the batteries just that slow at discharging?
can you explain this unlimited current thing? I didn't recall this.
Reply 6 of 10, by TheMobRules
A led is a type of diode, so if you connect it directly between Vcc and GND it will pretty much draw as much current as it is able to. And in a motherboard the PSU can output up to 20-30A on the 5V line, so it would pretty much blow instantly.
As for your experience with the battery, I guess it would depend on how much higher the battery voltage is compared to the led forward voltage, and also how much current the battery can deliver. In most cases it will probably end up burning sooner or later.
Reply 7 of 10, by Sphere478
TheMobRules wrote on 2021-03-23, 02:46:
interesting. 🤔 seems to make sense. thanks!
Reply 8 of 10, by adalbert
Batteries, especially smaller ones can indeed provide limited current, because they have so called internal resistance (just like they would have resistor wired in series with them). All batteries have internal resistance, but with large ones it is so small that it doesn't matter. Coin cells can have pretty high internal resistance, several ohms sometimes. Discharged or old batteries can also have higher internal resistance.
Reply 9 of 10, by Woody72
You're all correct, it didn't work 😄. I wired it into the 5v on a molex connector instead.
Reply 10 of 10, by Sphere478
adalbert wrote on 2021-03-23, 11:11:
makes perfect sense.
