First post, by mothergoose729
I was browsing the VIA Wikipedia pages, looking at lists of CPUs (as one does) and I noticed some unusual CPU models I have never seen before.
https://en.wikipedia.org/wiki/List_of_VIA_C3_microprocessors
I have a VIA C3 1.0A and 1.2A - neither are that hard to find. What I haven't seen before are the 1.3A and 1.4A PGA packages. I have been able to find the 1.3A "Mobile Pro" CPUs in BGA but I have never seen the 1.4A models in any package. I went looking on google and I can't find any image or any mention anywhere of a 1.3A PGA package and I can't find anything other than digital rendering of the 1.4A, 1.4B or 1.4C anywhere.
Were socket 370 versions of these processors ever actually made? Does anyone have one or has anyone seen a picture of them?
Just because I am curious, do you know if there are any BGA to PGA pin grids that work to adapt the BGA packages to socket 370? I think likely not (its a different pin layout) but assuming you wired everything correctly I would think they would be compatible.
    42.56 KiB
Reply 1 of 1, by mothergoose729
Found this interesting resources. It looks like wikipedia may just be wrong.
http://www.x86-guide.net/en/cpu/VIA-C3- ... o1888.html
The 1.3A models look to be EBGA - 368 not PGA 370. Some people apparently own one of the "A" models in 133mhz FSB and 200mhz FSB configuration - unsoldered some how.
Nobody seems to own or have seen the 1.4A/B/C models.
I think they were designed for products like these, which became available around 2004.
https://www.newegg.com/via-epia-sp13000-mini- … N82E16813181013
https://www.newegg.com/jetway-j627f800-oc-min … N82E16813153045
