blood 3dfx and .ini
First post, by blexford
I've been able to get Blood running great on my system.(Win 98, k61300, radeon 8500) and using a . bat file and 3dfx.exe. But I can't figure out how to get the movies to play or use Plasma pack. I tried adding blood.ini to the .bat but it doesn't work, or maybe I'm doing something wrong. Any advice?
Reply 1 of 3, by Unregistered
u cant play plasma pak or the movies?
Did u download the plasma pak 3dfx.exe?
Is blood.ini directed to your cdrom drive and is the cd in the drive?
Reply 2 of 3, by blexford
Thanks. I needed the Plasma patch, but I still have no movies though. They were installed on my harddrive, and work ok without the 3dfx. So I put in the cd and after updating the .ini it made no difference, and the .ini file looks ok. The CD music works ok, and I suppose I can live without the movies, but it would be great if I could get this game running as best as possible.
It's such a pleasure finally seeing this game as it was meant to be seen, and hopefully I'll figure this out.
Reply 3 of 3, by Snover
Either
  1. your video card doesn't support VESA,
    or
  2. 3DFX.EXE doesn't support video mode switching
    or
  3. 3DFX.EXE took out the videos.
In any case I don't think it's anything that GliDOS can fix, but Paul can certainly look into it.
Yes, it’s my fault.
