First post, by rad
Hi guys,
Recently I've acquired this motherboard (ASUS VL/I-486SV2GX4), Revision 1.7, without any additional voltage regulation (supports only 5V). The board was completely bare and stripped down, without any jumpers, bios, cache chip etc. Everything has been removed from it, so I've decided to give it a go and try to revive it.
The jumpers configuration of the board is different from those of 2.x revisions, more like revision 1.1 from here:
https://stason.org/TULARC/pc/motherboards/A/A … 6SV2G-VL-I.html
I've burned the latest BIOS (0402.001) from phils site on a new EEPROM chip, placed Intel 80486DX2/66 CPU (the only one that I've at 5V), VESA VGA card, some cache chips and some FPM ram and bam, the board started! Everything seems to be working fine.
Actually not everything, because it turned out my L2 Cache is not detected during POST - it showed Cache: None. I've placed initially 4 128kx8 kbit SRAM chips (-15) along with one TAG 32kx8 (again -15) and set the jumpers to 512k cache. Nothing has been detected. Tried also with the same number and value of chips (128kx8) but this time -10ns (I've had them from 5 years ago when I was building my Cyrix 5x86 133 @2x66Mhz system) - and again - nothing has been detected. Also tried with some other spare chips (4x 32kx8 and one 8kx8) for 128k cache but again no luck.
Tried downgrading the bios to from 04.02 to 03.03 and surprise - the cache has been detected! But it freezes the moment it tries to load MS-DOS. Either freeze or restart automatically. When I turn off the L2 cache in the BIOS it works great, I can run tests, programs, games, no problems whatsoever. But with L2 cache enabled it refuses to load the OS. Also what's odd is that with the 128k cache sometimes the BIOS detects it as 256k sometimes as 128k. What is also even more odd is that with 04.xx BIOS versions there is always an error for "keyboard not detected or faulty" at boot, but the keyboard is working fine, if I press F1 or DEL it continues, and on restart/reset it doesn't show that error. With older BIOS versions (03.xx) the message is missing at all and keyboard just works.
Unfortunately it is hard for me to take a full picture of the board as it is located in the tower AT case at the moment, but I've verified all jumpers positions and tried various other combinations. Probably it is still a problem with non-working cache chip, which later bios versions just automatically disable whole cache but older versions tend to try with it. I've ordered some 256kbit chips so that I could isolate chips problem (those chinese 128k -15 and -10 chips are unknown whether are working fine or not). I've tested all of them in a TL866-II programmer (with SRAM cache test) and they seem to work fine.
Any idea what could cause L2 cache issues? Faulty cache chips, bad socket/trace, chipset, CPU, Power supply?
Any help is appreciated,
Thanks!
Reply 1 of 5, by mkarcher
rad wrote on 2021-03-26, 08:28:
As you tried a lot of different cache chips, I don't think it's faulty cache chips. Also, faulty CPU is unlikely. The cache does not put a lot of load on the power supply, but of course might be affected if the +5V line is way too low (like 4.2V) or has way too much noise. Still, I don't think your problem is a typical power supply issue. This leaves bad socket/trace and bad chipset as options.
I had a very similar problem with my Biostar 8433UUD. In that case, the cause was a broken address trace. This is a very simple test you can do: All address pins (except one, typically A0) of all data RAM chips need to be in parallel. Also of all of these parallel pins should also appear on the tag RAM socket (if jumpered for a two-bank configuration). Also matching data pins of both banks need to be in parallel. Within a bank, all control pins (OE, WE, CS) are parallel, too.
On most boards, the cache chips are directly connected to the 80486 address and data bus. If that is the case, you can trace address and data lines up to the processor socket. All data lines from the processor socket need to get to the cache. In dual-bank 256K configuration, address lines A4 to A17 should be directly connected to the cache, too.
Reply 2 of 5, by rad
mkarcher wrote on 2021-03-26, 09:14:
874.16 KiB
Thanks for your advice! I've disassembled the board and started to check the parallel connections. So far:
- All OE pins are in parallel within the relevant banks
- All WE pins are in parallel within the relevant banks
- CS pins are in parallel only on 1st, 2nd, ... chips within both banks (only between chips 1 & 2, 3 & 4, 5 & 6, 7 & 8 in the screenshot)
I've started to look at the parallel address pins now, and that's odd:
- All address lines are only in parallel between chips in red zone and between chip in green zone (i.e. chips 1, 2, 3, 4 together, and chips 5, 6, 7, 8 in screenshot)
I'm going to check the links between CPU pins and cache address / data lines now.
Reply 3 of 5, by mkarcher
rad wrote on 2021-03-26, 16:36:
Thanks for your advice! I've disassembled the board and started to check the parallel connections. So far: - All OE pins are in […]
Despite what I said earlier, this is correct. The 486 does not always access the whole 32 bits at once. The CS pins are gated by the four byte enables, so you need four different chip selects within a bank.
It might be that the address lines from the CPU are amplified (or buffered, as you say in digital logic) by the two 74F245 chips for one of the zones and directly connected to the CPU in the other zone, because the board manufacturers considered two banks of cache to be too much load on the CPU address lines. This might explain the separation.
Reply 4 of 5, by rad
After further examining the traces on the motherboard, everything make sense now:
- Address pins from all cache chips are in parallel, not only those in red and green zones. It is just that different pins on the address bus have been used. For example, A4 address line is wired to pin A1 on cache chips 1,2,3,4 and pin A12 on chips 5,6,7,8, all those gated via one 74F245 input/output pin. It really doesn't matter, this has been done probably for optimizing trace paths.
- The only address pin on the cache chips that is not wired to the address bus is A8, which is in parallel on all chips on odd bank and on even bank. It goes to either KA3X - Cache address 3 for even bank or KA3Y - Cache address 3 for odd bank, on the chipset. Here I've found the first broken trace - chips 5,7 were not connected to chips 1,3 and to the chipset pin. The other bank - chips 2,4,6,8 are all good.
- Data pins from all cache chips are directly connected to the address bus. Every data I/O pin from one bank (4 chips x 8 I/O pins) is connected to a single data pin on the bus (32 bits total). Here I've found the second broken trace - D3 wasn't connected to I/O3 pins on chips 3 and 4.
First I've found the bad cache address trace, placed a jumper wire, but the board still refused to run properly. Then I've decided to remove the IC socket to see where exactly the trace has been damaged (the trace is on the front side of the board). It looks perfect, but there was no connection on its ends. After that I've discovered the bad data trace, but now I can't test it, because I'm still waiting for a new socket to arrive first. After I solder it will retest the board again.
205.03 KiB
Hopefully the board will be working fine, although 2 broken traces makes me think there could be more.
Reply 5 of 5, by rad
Thank you @mkarcher for your suggestions!
The board now works perfectly:
188.49 KiB
