First post, by ultra_code
Hello VOGONS,
For the past two days, as the title suggests, I've been having trouble installing Windows 2000 SP4 on this FIC PN-6210 system I've put together. I've tried many different things (different ISOs, different methods - either starting with floppy bootdisks or booting straight off the disks, manually selecting "MPS Uniprocessor System"/"MPS Multiprocessor System" in the F5 menu), all to no avail, with every attempt ending in a system reset upon arriving at the "setup is starting windows" section at the end of the initial driver loading sequence. I was wondering if anyone ever successfully installed Win2k on one of these boards with a similar config, and if so, would you be willing to tell me what you specifically did in order to get it to work.
My specific setup is as follows:
* Latest BIOS for the board (1.036)
* 2 Intel PPro 200Mhz 1MB CPUs, one of the SL259 SKU, the other one a SL25A SKU
* 256MB (4x64MB) 60ns EDO RAM
* PNY Nvidia FX5200 256MB PCI video card
* Adaptec ASH-1205SA PCI SATA controller card
Additional notes:
  • when I tried installing DOS 7.1 beforehand on a CF card over a CF-to-IDE adapter, DOS was not able to properly detected all 16GB of the CF card, even though the BIOS detected such, and after installation, the motherboard had trouble booting from the CF card. Only after hooking up a hard drive to the aforementioned Adaptec PCI SATA controller did things work as expected, and I was able to properly install DOS 7.1 without issue.
  • In my attempts to install Win2k, I have tried using both 98SE and ME bootdisks, immediately resulting in the following error message:
I am doubtful whether the Adaptec card, my GPU, or the differently SKUs of the same model of CPU are to blame for this issue, although I'm willing to try different PCI video cards later (I'm drained at this point today). I'm most likely leaning towards there being a BIOS misconfiguration, but even then I am confused as to what settings I have currently could even begin to explain this strange behavior. For reference, here are my current BIOS settings:
If anyone has experience with this board and/or a lot of experience with Win2K, your help would be appreciated. Thanks.
Builds
Reply 1 of 21, by liqmat
Disable "USWC Write Posting" pretty please.
Side note: I actually tested that board I sent you with Windows 2000 SP4. Worked fine. Also, the FX5200 does have troubles with numerous Socket 8 boards I've tested with. I would certainly try a more period correct video card. One of the ALR 6x6 recipients tried a 256MB video card in that system and also ran into a roadblock. As soon as they installed a video card with less memory everything went smoothly.
Reply 2 of 21, by ultra_code
liqmat wrote on 2021-03-26, 23:47:
Side note: I actually tested that board I sent you with Windows 2000 SP4. Worked fine. Also, the FX5200 does have troubles with numerous Pentium Pro boards I've tested with. I would certainly try a more period correct video card. One of the ALR 6x6 recipients tried a 256MB video card in that system and also ran into a roadblock. As soon as they installed a video card with less memory everything went smoothly.
Thanks for the reply. I will try changing that setting.
Also, very interesting in regards to the video card. Surprised that a GPU could cause such issues.
I'll report back shortly.
Builds
Reply 3 of 21, by liqmat
the_ultra_code wrote on 2021-03-26, 23:57:
Thanks for the reply. I will try changing that setting. […]
Does that SATA card have a Windows 2000 driver? It will need one for sure. During the setup process you will need to inject it manually if it does have a driver for Win2K.
Edit: Apparently it does >> https://adaptec.com/en-us/speed/sata/ash1205_ … _v10041_exe.php
Extract the exe onto a floppy and install the driver during the Win2K setup when it asks if you want to install third party drivers (F6).
Double pretty please: Those particular VRMs you are using are the original FIC VRM models and get quite toasty. Highly recommend you blow a fan across them while using the board. Actuallly, nevermind. Just noticed the Godzilla black fan at the top of the pic. You so smart!
Reply 4 of 21, by ultra_code
liqmat wrote on 2021-03-26, 23:59:
Does that SATA card have a Windows 2000 driver? It will need one for sure. During the setup process you will need to inject it m […]
I've tried loading said driver during the driver loading sequence, and the Win2k installer correctly reads the driver, but it doesn't change anything. Besides, I can install the driver afterwards like I did with Win9x I'm pretty sure. And yeah, I can put a fan over the VRMs.
As for the changes I made (disabling that USWC option, and swapping my FX5200 with a Matrox Millennium 2 with WRAM expansion card), still nothing. Also, on the reset after a failed attempt from selecting "MPS Multiprocessor System," I got this error code that froze the system on POST. I had also got this error whenever I changed the "Power Management/APM" setting in the BIOS.
https://i.imgur.com/81gkzyZ.mp4
Perhaps there's a memory error of some sort, although it's strange that Memtest86 didn't pick it up.
Builds
Reply 5 of 21, by Warlord
it's either bad ram, bad hard drive. even if it seems good. there's something wrong with one of them. id be willing to wager setup just doesn't like your sata card or the way you have that hard drive hooked up. can you try hooking up a normal ide hard drive known to be good.
If that works after you install windows, install the sata card driver and hook a hdd up to it. Then use ghost to image the drive over.
Reply 6 of 21, by ultra_code
Warlord wrote on 2021-03-27, 00:33:
Most likely RAM. After removing all drive-related stuff, leaving only the optical drive, I still get the same issue. I'll buy some more RAM and report back.
Builds
Reply 7 of 21, by maxtherabbit
That error message indicated the lack of writable storage media. Of course it would come up with nothing connected but the CDROM
FYI I use a FX5200 on my dual PPRo and it works perfect
Reply 8 of 21, by maxtherabbit
I never had a problem with that setting being on, but I did have to disable "read around write" to get mine stable
Reply 9 of 21, by Warlord
maxtherabbit wrote on 2021-03-27, 03:56:
exactly.
The way to go about it is, to test the ram with memtest86 floppy boot. Not just assume its bad ram, that message has everything to do with writable storage aka your hdd.
There are different scenarios here.
Scenario 1 Motherboard doesn't like Sata controller card
Scenario 2 motherboard just doesn't like the slot that you slotted it in becasue its on a pci/isa bridge
scenario 3 Sata controller doesn't like the ssd attached to it
scenario 4 windows 2000 doesn't like the ssd
scenario 5 the way the ssd is formated windows 2000 doesn't like aligned partition
scenario 6 all of the above and any combination
Reply 10 of 21, by liqmat
I had issues with an ALR dual Socket 8 board and another member with his ALR 6x6 when a 256MB video card was installed. Just my experience so I thought I would put it out there. Most likely a compatibility issue with those boards. Nonetheless, I completely didn’t read the OP’s error screen when I first replied. What I get when trying to multitask. I tested that board using the onboard controller and it worked fine with Win2k SP4.
Reply 11 of 21, by maxtherabbit
Warlord wrote on 2021-03-27, 04:14:
exactly. The way to go about it is, to test the ram with memtest86 floppy boot. Not just assume its bad ram, that message has e […]
exactly.
the most likely scenario is that win2k simply doesn't have a driver for the SATA card and needs an F6 install from a floppy disk
Reply 12 of 21, by liqmat
maxtherabbit wrote on 2021-03-27, 15:51:
I already mentioned that above with links. Talked to him on Discord. He tried that without success.
Reply 13 of 21, by maxtherabbit
liqmat wrote on 2021-03-27, 16:02:
Hmm well if it were me I would just hook up a known good mechanical IDE drive to the onboard controller and establish a working baseline before doing anything else
Reply 14 of 21, by liqmat
maxtherabbit wrote on 2021-03-27, 16:08:
100% works with an IDE drive using the integrated IDE controller in Win2k SP4. I tested his board with that config right before it left my hands. The board does have a HDD size BIOS limitation (I was able to format a 10GB IDE drive with no issues) even with the latest beta BIOS revision. I believe he hit an 18GB ceiling with the latest BIOS IIRC? That was considered huge in 1996 which these boards are dated.
I took a few photos during testing the Win2k Pro SP4 installation right before it went out the door.
The attachment FIC PN-6210 Win2k SP4 Install Test.jpg is no longer available
The attachment Doom95 FIC PN-6210 Win2k SP4 Test.jpg is no longer available
The attachment Doom95 FIC PN-6210 Win2k SP4 Load Test.jpg is no longer available
The attachment Gunmetal FIC PN-6210 Win2k SP4 Test.jpg is no longer available
The attachment Gunmetal FIC PN-6210 Win2k SP4 Load Test.jpg is no longer available
Reply 15 of 21, by ultra_code
Sorry for the late reply. Just getting around to this today.
Just in case it's the RAM, I going to run MemTest for at least 3 passes, as that's usually enough to find any issues with RAM (when I got the RAM, I did 1 pass making sure it all "worked"). If nothing still, then I suppose there is no doubt storage is the problem. I just bought an 8GB DE hard drive to test with, as I don't currently own any.
I still find it strange, though, that DOS 7.1 had no issues with the SATA controller, and detected everything just fine, though I suppose that's DOS for you.
Builds
Reply 16 of 21, by Warlord
that could be just that the int13 works just fine, and its the f6 driver that windows 2000 doesn't like or doesn't have.
Reply 17 of 21, by ultra_code
@Warlord @liqmat @maxtherabbit I come bearing good tidings.
So, what, two days ago?, I went ahead and started testing the RAM as I said I was going to do, getting it my 3 passes of MemTest in after 5+ hours. After all of that, nothing. The RAM was not the culprit like I thought it might have been. However, things didn't sit with me right. You guys kept saying that storage might have been the issue, and yet, I couldn't 100% believe that. I decided to do some further troubleshooting. I swapped the optical drive, I tested with an 8GB CF card in a CF-to-IDE adapter, and even swapped the PSU with a modern one, just to rule out all of the possibilities I could, and still, nothing...
While waiting for the IDE hard drive, I decided, for the heck of it, to do the last thing I possibly could, not related to hardware - reset BIOS defaults. I thought that perhaps if the hardware wasn't to blame, then software must have been at fault. I had already tried two different Win2K ISOs, and even tried an XP SP3 ISO, which instead of resetting the system, only hung the system. So, I reset the BIOS settings to default, hooked up the 8GB CF card as my test drive just to give the Win2k installer a drive to look at, booted off the Win2K disc again, and...
I then went about slowly reconfiguring the BIOS the way I had it before with the intent of finding the offending BIOS option. I lastly came to the sub-option underneath "USB Function" - "USB Keyboard/Mouse Support." When I enabled that sub-option, it would cause the issue I was experiencing - crashing of the Win2K installer after loading in drivers off of the CD. Further inspection upon loading the Win2k installer with the option disabled shows that, right after loading up the drivers off the disk, the installer will proceed to configure something in regards to keyboard support.
Reading the manual after making the discovery, it states that if you aren't using a USB keyboard, you shouldn't enable that option. I had been using a PS/2 keyboard exclusively up to this point, and had thought that for whatever reason, enabling that option was required for USB keyboard/mouse support under Windows, but in hindsight I presume this BIOS option provides USB keyboard/mouse support to OSes without such support built-in, or something of that nature.
12+ hours of troubleshooting thanks to the complexities of keyboards...
With this out of the way, I set up the testbench similarly the way I had it (FX5200 + PCI SATA controller and 256GB SSD), inserted a stock SP4 Win2k installer disc in the optical drive, and loaded the driver for the controller card off of the Gotek. I formatted the SSD just fine, installed Win2K without issue, and have finally reached the Win2K desktop. All I have to do now is install drivers, and get to doing what I wanted to do from the get-go - testing this old platform for myself.
Sorry for the slow responses. Also, can't believe this is what wasted our time. 😒
Builds
Reply 18 of 21, by mwdmeyer
Hah don't you just love computers sometimes? It is half the fun, sort of. Glad you got it working!
Reply 19 of 21, by liqmat
Haha awesome and good to know. The biggest complaint of that motherboard model is they reversed the order of the keyboard and mouse PS/2 ports from the usual manufacturer standard. So I got a few people asking me why the ports didn't work. They do, just switch them around. Out of the 25 or so NOS FIC PN-6210 boards I had, only two had issues. Not bad after 22+ years of sitting in a box. You will find they are good performing boards and from my experience, stable as a rock.
I also see you put Godzilla right over the VRMs. Nice!
