Ah yes - did something almost the same on my Qube 3, except mine is running Debian Jessie....It's old, but not that old.
The attachment Webmin 1.971.png is no longer available
The kernel has been updated to 3.4.8 - was working on a 4.17 kernel earlier but it ran into a build issue (related to Debian bug 848066) so it was back to the 3.4.8 for now.
The attachment Display.png is no longer available
Whats inside? 450MHz K6-3+ (Sharptooth) - mostly so I can manage the power consumption with clock-back on idle, 1GB of PC100/133, 2 NatSemi FastE NICs, and a Promise SATAII dual port controller (yeah, I know, good old 32 bit PCI is not enough to run a single SATA150 port, much less 2 SATA300...of course, dealing with hard drives, it's plenty enough).
The attachment specs.png is no longer available
I did swap out the original Delta fan for a SileX 60mm fan with rubber mountings that ran much quieter, and the primary drive on IDE0 was replaced by an 8GB industrial IDE44 drive, and then by an IDE44-to-SD adapter simply because digging a bad kernel build out and fixing it on my linux machines take much longer with the industrial IDE (I'll need an IDE-to-USB adapter) than with the SD.
The attachment Interior.png is no longer available
What's the long term plan for it? Probably not much - the machine was long replaced by my HP MicroServer G7/N40L (which is currently my RAIDz10 array), which in itself is old enough to be considered retro. The computing end is already supplemented by a Ryzen embedded box on top. I could toss a few old SATA1 drives in there to make it a ghetto NAS, but eeeeeh, why bother.
The attachment Replacement.jpg is no longer available
