First post, by Dzejrin
Hello everybody!
I recently bought the HP T5710 thin client. I'm going to install Windows 98 SE on it using a bootable USB stick. In fact, I already tried to do so. I used HP USB Disk Storage Format Tool to create a Windows 98 Startup Disk and copied install files from the CD. I even managed to boot the USB stick and start Windows setup, but...
I have 5 available Flash Disks from which 2 are completely dead and cannot even be formatted. 1 is faulty and always fails during setup reporting damaged .CAB file (each time I formatted it at different stage). Remainig 2 are not booting in the thin client, therefore I assume they are incompatible. I also tried USB Card reader which maps SD Card as a mass storage device. Also not booting...
Finally, to my question. Does anyone know which USB sticks are working with this machine? Or can you please tell me which sticks did and did not work for you? So that I will know which one to buy.
