Hot EMU8000
First post, by Ydee
On the back of the SB32 sound card I see a visible change in the colour of the PCB caused by the heat load from the EMU8000 chip. The chip was very warm to the touch, so I fitted it with at least a passive radiator with hot-conducting adhesive tape. I mean, is this heat load normal or is there something wrong with my card?
    248.28 KiB
    210.69 KiB
Reply 2 of 7, by Tiido
Chips that have IC405A written on them do get hot but not this hot, this is definitely not normal.
Reply 3 of 7, by Ydee
Thank you for your input. Yes, it is IC405A. The card was originally installed in the lowest ISA slot in a small AT case and I'm afraid the airflow there was zero (no case fan) - so is it possible,that there was local overheating? Or is it still an abnormal condition? Then what could have caused it?
    664.11 KiB
    135.36 KiB
Reply 4 of 7, by The Serpent Rider
Age + internal flaws in silicon/chip connections, potentially static discharge.
Reply 5 of 7, by Cyberdyne
well these little faulty/little hot chips may be ok for years to come, and they may die tomorrow. I have first had experience. even chips that should be cool as a cucumber.
Reply 6 of 7, by Ydee
Thank you all. Anyway, the card's working fine so far, so I'll leave the passive radiator and see. Interestingly, the PCB coloration is only on the back and not around the EMU8000 chip from the front. At first I wondered, if there might have been some other hot chip, that would have turned the PCB brown, but I couldn't think of an ISA/VLB card, that would have been hot enough to overheat a card in the neighborhood.
Reply 7 of 7, by The Serpent Rider
Cuz physics.
