First post, by Wilius
Hello.
I have a Olivetti Echos Pro150 SL, which isn't working.
Like I said in the title, it first turns on, then starts beeping and after that, proceeds to shut down. While this happens, the screen stays black.
It does 1 beep with a pause followed by 3 more beeps. Unless it turns itself off, it repeats this beep code a second time and stays silent afterwards.
Sometimes it just turns on and shuts down, without beeping at all.
I already did some researches on my own. One person said, this beep code means there's something wrong with the CMOS Ram and another person said it'a graphics chip / vram related issue. Both things are possible.
I noticed, there are several things wrong with the machine. First, this Laptop has been taken apart before, and second the CMOS battery had leaked.
I immediately removed the CMOS battery and cleaned the whole motherboard by using 99.9% isopropyl alcohol, diluted vinegar and dried it carefully.
I havn't viewed the board under a magnifying glass yet, but it's very likely, that there's some damage, caused by the battery acid.
Is it possible that a CMOS battery is required for this thing to boot?
Has someone an idea, if this is fixable and if yes, how?
I appreciate any help. Thanks in advance.
Here is a recording of the beep tones: https://youtu.be/qL5VoX1ncMI
Sorry, the video is turned 90°. That wasn't supposed to happen. I recorded it on my phone.
I'll also make sure to add pictures ASAP. Until then, I beg for a little patience.
edit: after doing some further researches, a third person pointed out, that the RAM could also be the problem.
Reply 1 of 2, by Wilius
Sorry for being impatient, but is there anyone who can please help me?
The best thing would be, if someone could provide me the user manual.
I couldn't find it anywhere.
In case my question doesn't belong here, please tell me.
Perhaps someone can recommend me a different forum.
Reply 2 of 2, by Wilius
First and foremost, I can now confirm, that the RAM isn't the problem, as the memory module is working fine in a different machine.
Second, as promised, I finally managed to make some pictures of the motherboard. Sadly they are pretty blurry. I likely have to reshoot them again with a better camera.
The pictures are closeups of the spot, where the battery used to be and shows what damage it caused to the motherboard. On the first glance, I thought the traces looked fine, but upon closer inspections, I noticed that some of the traces where completely gone. They got corroded so badly, that they have disintegrated.
Is there any way to fix the traces? If yes, how? I can't find any contacts, where I could solder on botch wires.
