First post, by Bernkastel7734
Hello,
so I got motherboard with old type barrel-type battery(Pic 1). Can I just solder it out and replace with a socket for 3V CR battery, or I need to find 3.6V new bartery. Does that .6V make a big difference ?
Reply 1 of 8, by chrismeyer6
You can replace it with a standard coin cell just be sure to use a diode to prevent the motherboard from trying to charge it. It looks like there maybe some corrosion as well so that needs to be addressed as well.
Reply 2 of 8, by dataino.it
Solder a "CR2032 batty holder" to pin signed in photo
    45.18 KiB
    72.06 KiB
Reply 3 of 8, by Bernkastel7734
chrismeyer6 wrote on 2021-04-09, 12:28:
Okay, does that matter if I connect the diode to positive or negative side of the battery socket?
Reply 5 of 8, by Bernkastel7734
Soldered out old battery, there is no corrosion or leakage on the motherboard itself, just on the battery.
Reply 7 of 8, by majestyk
It doesn´t matter if the diode is put in the positive or negative battery connector. The polarity must be correct.
And it´s a good idea to use a Germanium or Schottky diode, because they have far lower voltage drops of 0.2 - 0.4V as opposed to 0.7V of Silicon Diodes.
With a Schottky or Germanium (harder to find these days) type diode the voltage of the lithium cell is high enough for a longer time span so you save money.
Reply 8 of 8, by Bernkastel7734
majestyk wrote on 2021-04-10, 06:18:
My Granddad has been working with electrical parts since 1950 so I have a lot of stuff in my garage. Used Schottky diode. Now motherboards holds bios setting. Thanks for help.
