First post, by Gambit37
- Oldbie
You previously told me about the limits of the PNG transparency Paul -- that two objects with semi-transparent pixels, when seen together, the topmost object would appear to punch holes in the background object where the semi-trans pixels occur.
However, I've noticed that this behaviour is inconsistent.
I can get the upper object to display perfectly with it's semi trans-pixels blended perfectly with the pixels of a lower semi-trans object. It's weird but it seems dependent on the direction the camera is facing and the number of items in view.
Do you know why this might happen?
