First post, by Miphee
I noticed that 4 of my mobile CPUs have a hairline crack in them. Overheating maybe? Didn't the Core Duo and Core 2 Duo mobile series come with the thermal throttling feature? I have lots of mobile CPUs and this is the first time I've seen cracked ones.
    181.06 KiB
    219.03 KiB
    242.96 KiB
    183.16 KiB
Reply 1 of 6, by pentiumspeed
Bad handling and bending the package, too much pressure on heatsink (pressing, rocking the heatsink too hard), causes this crack, Look at the edges are nicked badly. Lap your heatsink smooth with 600 to 1000 grit wet/dry sandpaper lightly, clean 3 times and very clean, and thermal paste replaced when reassembling.
I also have some nicks at edges of the die but did not crack them since I had been careful with them.
Cheers,
Great Northern aka Canada.
Reply 2 of 6, by Miphee
pentiumspeed wrote on 2021-04-11, 17:48:
Cheers,
I didn't think of that, thanks. I never actually used any of these CPUs, I just collect them. The last time I've seen cracks like that were on heat-damaged socket 370 Celerons and 462 Athlons. But the heatsink idea is more logical.
Reply 3 of 6, by cyclone3d
Are you sure those are cracks and not just scratches from the heatsinks or improper handling?
I recently took the cooler off an MSA R9 280 video card that was given to me because it was having issues and the die was scratched from the rough surface of the cooler base.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 6, by Tiido
Yeah, those look like scratches on the surface.
Reply 6 of 6, by Miphee
It's hard to take a good photo of these they are so small. When I run my nails across the surface it feels jagged like a cracked surface.
They are almost identical and run through the entire surface of the die. I got them in this condition many months ago but I don't have socket P or any other notebook mainboards to try them. They don't show any sign of burns or discolorations like burned desktop Athlons or Celerons.
Pentiumspeed is probably right, someone must have over-tightened the heatsink screws.
